Motherboards Quad core xeons
Discussion in 'Hardware' started by tech3312, 25 Jul 2010.
  1. tech3312
    tech3312 Where's my dremel o.0
    1 Apr 2007
    Hey I'm planning to purchase a HP Proliant for $330 that supports quad cpu socket 604 and i found some socket 604 xeons quad cores for 45 bucks they have 91 in stock. I was wondering if the Proliant G2 support Quad-core xeons I highly doubt but want to make sure in case i miss a deal like that.
  2. confusis
    confusis Kiwi-modder
    5 Jan 2006
  3. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    do you mean a Quad socket motherboard, and your looking for the compatible 4-way single core xeons, as the 604 socket never had a Quad core CPU's nor Duals.
    Personally I would spend $330 on a native quad core CPU build, consume less power, cooler and only requires one heatsink+fan to cool the processor so noise is low, if not silent depending on the build.
  4. tech3312
    1 Apr 2007
    @confusis it is mobo that you showed in the link.
    @Burnout It's 4 socket CPU that accepts socket 604 and i found a quad core CPU (4 cores in a cpu) if the proliant g2 does accept quad cores then in-total I'll have 16 core in a server get my drift now?
    cpu http://www.compuvest.com/Desc.jsp?iid=1141839
  5. confusis
    5 Jan 2006
