Other Quadcopter Parts in the UK
Discussion in 'General' started by Silver51, 9 May 2014.
  1. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    I have a Blade 350QX quadcopter, which is great but the non-standard propellers that come with it are something of a liability. After having one break on take-off (which crashed the quad into a beach) I decided to buy a set of adapters to fit standard props with a 6mm spindle.
    I also picked up a set of APC 9x4.5inch Multi Rotor blades.
    The problem is that APC talk about the use of adapters but as far as I can tell, their Multi Rotor specific propellers don't ship with them. Also, the ones they do supply on their own seem to be manufactured for either the Slow Flyer or E type props.
    Does anyone have any experience with aftermarket props for quadcopters? Also, does anyone know any reliable UK suppliers?
  2. DeadP1xels
    30 Nov 2009
    Probably not what you're after because I don't know much about quads
    But this is a site I use a lot and they have a small selection of quad parts on there and ship stuff pretty damn quick and reliable.
    http://www.coolcomponents.co.uk/uav
    Silver51 likes this.
  3. *Alex*
    *Alex* What's a Dremel?
    23 Mar 2008
    HobbyKing has loads of quad copter parts I know they are not based here well some stuff is some isn't but they will ship to the UK if you want something from another warehouse, and the parts are pretty good for the price's.
    http://www.hobbyking.co.uk/hobbyking/store/index.asp
  4. Silver51
    24 Jul 2006
    Thnaks for the replies. HobbyKing seem to have the parts I was looking for, specifically some 9x4.7 props with adapters.
