Education Quadratic Graphs
Discussion in 'General' started by ocha, 11 Dec 2007.
  1. ocha
    ocha Minimodder
    29 Dec 2001
    just a quick one that I would really appreciate some help with
    Is there any way on a quadratic graph that it can have just one minimum but a value of the power of x is between 1 and 2.
    I.e if I have a equation of y = 3 * x^1.7 can that still give me a quadratic graph?
    Any quick help is really appreciated
    Ocha
  2. Krikkit
    21 Jan 2003
    y = 3 * X^1.7 is a single-valued curve, i.e. every unique point on the x-axis maps to another, unique point on the y-axis. It has no minimum per se, not even a turning point because after you cross into the negative boundary, you end up with complex (aka imaginary) numbers.
    So in an answer to your question, no, you can't have a sub-quadratic graph with either a turning point or minima...
  3. ocha
    ocha Minimodder
    29 Dec 2001
    ok so on that basis the only way a graph could turn and have one minima would be if it had was something along the lines of
    y = 3 * x^2
    i.e. the 2 being the key?
    ocha
  4. radodrill
    radodrill Resident EI
    14 Mar 2006
    The only way a y=c*x^p curve will only have 1 absolute minimum is when c>0 and p=2*n with n=1,2,3,4,....
  5. radodrill
    14 Mar 2006
    Incorrect; imaginary numbers are a result of the power being negative (i.e. y=c*x^p with p<0)
  6. Glider
    Glider /dev/null
    2 Aug 2005
    No, X^(-2) = 1/X^(2)
  7. radodrill
    14 Mar 2006
    D'oh my head wasn't on straight :duh:
    Meant to say complex numbers occur when 0 < |p| < 1 and x < 0
  8. Amon
    Amon inch-perfect
    1 Jun 2007
    To put it simply, the function is discontinuous when x < 0. That means you can't differentiate the point x = 0, and therefore there is no rate of change and no minimum can be mathematically derived (you cannot take the limit of x -> 0-; the rate of change as x approaches zero from the left)
    So I guess a proper answer is to say that the lowest perceivable (meaning unproven) point of the function is x = 0, but you cannot mathematically prove it since the x < 0 is undefined. It's a valid function, just no way of proving a minimum using derivatives aside from common sense.
  9. radodrill
    14 Mar 2006
    only semi-discontinuous for x<0 if the absolute value of the power is between 0 and 1 (results complex numbers) or if the power is 0 (horizontal line)
  10. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    And you're assuming that c > 0. If c=0, it's a straight line along y=0, if c<0, the formula will approach -infinity at both ends and have an absolute maximum.
  11. Krikkit
    21 Jan 2003
    I was trying to put it reasonably simply. You'll end up with a purely imaginary number in this case, but lumping the two together isn't necessarily (imho) a bad thing, but only when you don't need the details.
  12. radodrill
    14 Mar 2006
    correct as long as the power is p=2*n with n=1,2,3,4,...
    other case for an absolute maximum is when c>0 and p=-2*n; absolute minimum also for c<0 and p=-2*n
