News Quake 4 supports X-Fi
Discussion in 'Article Discussion' started by WilHarris, 3 Nov 2005.
  1. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
  2. ch424
    ch424 Design Warrior
    26 May 2004
    It'd be good to know if that actually works. It fails to detect my audigy 2 properly, claiming it doesn't support EAX 3.0 or "Advanced HD", which it obviously does. :(
    ch424
  3. mclean007
    mclean007 Officious Bystander
    22 May 2003
    I'd definitely have one if I were building my dream gaming rig. It would be fairly low on the list, however - I'd probably be fitting an A64 X2 4800+, 2x1gig decent speed RAM and a pair of 7800 GTs in SLI before thinking about splashing £150 on a soundcard. As it stands, I'm running 2x256MB of PC2100, and a 128MB radeon 9600 pro on an XP 2200+, so my dream system is a looooooooong way off!!
  4. Darkedge
    Darkedge Minimodder
    26 Nov 2004
    I fancy an x-fi board but one major thing puts me off them.
    NO SPDIF ON THE BACKPLATE.
    I want spdif out the back of my comp (pref non optical) not a cable hanging down the from from a breakout box.
  5. Hans Voralberg
    Hans Voralberg What's a Dremel?
    12 Mar 2005
    So in order to benefit i have to go with the x-fi that have xram ? And does its enhance anything on headphone at all? cause i dont have 5.1 lol
  6. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    is creative trying to get some kind of direct X standard for audio (ignoring the fact direct sound already exists)?
    if so and if it had enough cool features/big enough Fps boost it may just help them combat high quality onboard audio.
  7. sadffffff
    sadffffff Minimodder
    20 Oct 2003
    i hope the sound isnt anything like quake 2's sounds!!! if so just mute it. 9000% better
  8. Reaper_Unreal
    Reaper_Unreal What's a Dremel?
    16 Apr 2002
    There are actually 2 major audio standards, DirectSound (which is kind of ugly to use) and OpenAL (which is slightly slower, but is multi-platform). It's much the same comparison as DirectGraphics (Direct3D) and OpenGL.
    As for buying an X-Fi, I was considering it, but then I realized that my Audigy Gamer is fine for gaming, and if I was worried about sound quality I wouldn't go near creative, and go straight for a M-Audio card. I don't really see the point in buying a card like this if you already own an Audigy of some sort unless you have a massively expensive stereo system and you want gaming performance more than audio fidelity.
  9. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
  10. keir
    keir S p i t F i r e
    5 Oct 2003
    Doesnt Battlefield 2 support X-fi as well?
  11. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Why dont they just support DD EX or DTS ES in games.. All i need is a digita/opti out and hook it to my DD/DTS reciever. Just one card with a good encoder and dig/opti out support of suround sounds. This card will be small and cheap. (like the ethernet cards nowadays) Or could be made onboard. Remember that motherboards with dig/opt out are not supporting full Digital suround on the outputs!
    You can put a headphone into your reciever headphone socket this will result in way better signal output then from a soundcard.
    just my 2 € cents...
Tags: Add Tags
