Peripherals Quality Powered eSATA Cable
Discussion in 'Hardware' started by Blogins, 21 Nov 2011.
  1. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    I have a powered eSATA connection on my ASUS P8P67 Deluxe Motherboard and I'd like to take advantage of it. So I'm looking for a quality powered eSATA cable of a decent length. Obviously it needs a strip on one end for connection of SATA and POWER to the HDD or SSD and then a powered eSATA connection of the other to link it with the motherboard!
    Recommendations appreciated.
  2. GoodBytes
    20 Jan 2007
    You mean something like this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16816104013
    (I know you are not in the U.S... this is just for me to know, if this is what you are looking for).
    I don't know any HDD enclosures that takes power from eSATA, only USB-like memory keys, but on powered eSATA, instead of a USB plug.
    In my case, I use a normal size HDD enclosure, which take eSATA, and is powered via a power plug.
  3. Blogins
    3 Aug 2010
