question about a part
Discussion in 'Modding' started by Kenneth Jørgensen, 7 May 2020.
  1. Kenneth Jørgensen
    Kenneth Jørgensen What's a Dremel?
    31 Jan 2020
    Hi i am building a new cnc machine and i have in some of alex videos seen him using
    som mounting cubes i beleve that it is for M3m do any one know there you can buy them for a good price in the EU
  2. Arboreal
    21 Jan 2011
    Hi Kenneth, welcome to Bit-Tech!
    I am starting a project soon, and may need some myself, which is why I have these details to hand!
    Parvum do them in packs of 10 - 12mm Modding Cubes
    Farnell do them in 10mm - the UK Page shows UK and EU stock, so that may help shipping. Without looking, I would say that the £1.10 is without VAT, so £1.32 + shipping
    Hope that helps
    adidan likes this.
  3. adidan
    25 Mar 2009
    Welcome Kenneth :thumb:
    @MLyons may know what Alex uses, I think he'll be around more often than @Maki role at the moment.
    Edit: sorry, I think @Arboreal gave you the answer anyway. One of those days for me. :duh:
    Arboreal likes this.
  4. Arboreal
    21 Jan 2011
    Thinking about it further, I would guess that Alex uses the Parvum cubes as they have worked together on a number of projects over the years
  5. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    They're not the parvum or OCUK ones as they're pretty expensive. Alex gets them from somewhere else and buys them in bulk. think they're 12x12mm with m3 holes on all sides. You could join the discord and ask him as you're more likely to get a response but he should be on here soon.
    Arboreal and adidan like this.
  6. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
  7. Arboreal
    21 Jan 2011
    Thanks Alex, good to know.
    Even at a 100pc, they don't seem much cheaper than the ones I listed.
  8. Kenneth Jørgensen
    31 Jan 2020
    Thanks for the info
