Electronics Question about buying LCD's
Discussion in 'Modding' started by bogdan_lupuro, 20 Jun 2006.
  1. bogdan_lupuro
    bogdan_lupuro What's a Dremel?
    15 Feb 2006
    Hi everyone
    I would like to get myself a lcd to connect it to the PC to dsplay various things.
    But i don't really know what to get.
    What things should i consider when buying one? How about if i get a display from a cell phone will that work ?
    Thanks
    Bogdan
  2. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    it depends on the controller. if you want a text based lcd then the HD44780 controller is the one you want. if graphical is what you are looking for then there are some common ones off the liquidmp3 site
    * T6963C
    * SED1330
    * SED1335
    * KS0108B
    * Noritake 800(A)
    * Noritake 311
    * LC7981
    * HD61830
  3. bogdan_lupuro
    15 Feb 2006
    I've found an HD44780 wich looked cool Is it ok ?
    Bogdan
  4. bender386
    5 Jan 2006
    got a link???
    just about every HD44780 lcd is the same so it should be fine.
  5. bogdan_lupuro
    15 Feb 2006
  6. bender386
    5 Jan 2006
    i love mine. at the moment its not pluged in becuase im making a case for it.
    it normaly shows things like fan speeds, temps, cpu usage ram usage, harddrive space, time and ip. it changes to music mode when winamp is open.
    i use lcd smartie which seems to work very good.
    those ebay deals look ok. looks like you get everything you need to get it up and working which is good.
  7. bogdan_lupuro
    15 Feb 2006
    Cool thanks for all your help....i'll order
    Thanks
    Bogdan
  8. bogdan_lupuro
    15 Feb 2006
    BTW do you think i can fit the second the 20x4 in a single cd-rom bay and maybe a litlle more approx 1 inch ?
    Bogdan
  9. bender386
    5 Jan 2006
    the lcd is 98.0 x 60.0
    and a cd-rom bay is 146mm x 44mm
    so it will take up 2 slots.
  10. bogdan_lupuro
    15 Feb 2006
    Thanks again....but i have another question
    Where can i buy from other place than ebay something like that with all the things needed to get it started....because i'm having only problems when buying from ebay.
    So i need somewhere where i can buy without Paypal....direct from website.
    Thank you
    Bogdan
  11. coorz
    coorz Miffed
    25 Apr 2003
    What country are you from then? There are loads of websites that sell character displays, but more likely more expensive than ebay.
    edit: this Dutch site ships to Europe, though i do not know the shipping costs. And their prices are reasonable.
  12. bogdan_lupuro
    15 Feb 2006
    I am from Romania. I know that they are more expensive but don't have what to do else.
    Bogdan
    Btw i've seen matrix orbital has some great things. But i don't know what to buy from there
  13. Kickn
    Kickn What's a Dremel?
    7 Oct 2003
    I've been selling some nice ones on ebay - 20 x 4 - blue on black - if any is interested PM me - they are going for about £8.
