Modding Question about clearcoating Alu
Discussion in 'Modding' started by shaq, 10 Nov 2006.
  1. shaq
    shaq New Member
    7 Sep 2006
    Hi, I've been reading the guide in this forum about polishing alu, and it mentions the need to 'clearcoat' after polishing. I understand the concept but where would I get this clearcoat from? An brand name I should look for (available in the UK?)
    Thanks!
  2. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    "Clearcoat" refers to any clear paint, and is used to protect the paint or other finish underneath. Personally, I'd recommend Krylon brand, but I'm not sure about availability in the UK. I'd look in auto parts stores, home improvement places, and even someplace like WalMart (Asda, if I'm not mistaken). All these places should carry the stuff.
  3. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    There's also Dupli-Color automotive spray paint.
    There are alternatives. You can polish it up, buff it up, glaze it up, and then wax it up. I'm slightly concerned about how the clear coat will adhere to polished aluminum.
  4. ShaqArif
    ShaqArif New Member
    9 Oct 2006
  5. crazybob
    21 Oct 2004
    Yeah, that's exactly what I'm talking about. However, I admit Stuey raises a valid point. Polished aluminum isn't the best base for painting, and you might be better off with another approach. If you paint polished aluminum, the paint will all peel off in a matter of days.
    A better solution is to wax the aluminum. Ordinary automotive wax should work just fine. Waxing won't protect against scratching, so you'll have to be careful with it, but waxing will keep the surface shiny and prevent it from oxidizing and turning hazy. You'll also need to rewax every few months.
  6. Stuey
    20 Jan 2005
    If you really want to get a spray can, there's GOT to be a better source than that. That price is almost $11 USD whereas a it should cost mo more than about a quarter of that.
