So I have a few questions about the fittings. I was looking at a few brands of fittings Monsoon,ek and alphacool which ones would be the best to use? Also say the tube has a slight angle on it when it goes into the fitting will it leak or does it have to be perfectly straight?
It doesn't have to be perfectly straight, but at the same time, the o-ring needs to be sealing it entirely. As long as your o-ring is entirely on the tube, you will be fine. You should, however, aim to make it fit as straight as possible.
Thanks that’s what I kinda figured. Gonna start ordering some water cooling parts tomorrow and maybe order some tubing to practice with
ya i mean im an auto tech ive done fuel and brake lines so hoping that will help. Just trying to figure out what fittings i want the monsoon ones look amazing but i havent really heard of them, last time i did water cooling i had a 9800gtx and a E8400 lga 775 lol
