Question about KVM and Gaming...
Discussion in 'Hardware' started by Blood, 21 Nov 2004.
  1. Blood
    Blood What's a Dremel?
    4 Jan 2004
    I want to use both my computers on one monitor via a mini kvm,
    Will this Affect my monitor in terms of gaming ? I play hl2, dow, doom3, cs.s all the newer games....
    Jus wondering...
    Thanks
  2. N4N01D
    N4N01D What's a Dremel?
    29 Apr 2004
    it shouldnt, if anything i only see a very very slight downgrade is picture quality, only noticible because i have a 2nd monitor beside it to compare too
  3. Blood
    4 Jan 2004
    Cool thanks,
    My monitor atm is dodgy , it flickers , im used to it but other are like :O
    Upgrading to 17 inch tft soon anyway
    Ty :)
  4. ChegsJAR
    ChegsJAR What's a Dremel?
    7 Sep 2003
    I don't notice any different with my kvm plugged in or with the monitor plugged straight into the video card.
  5. biff
    biff What's a Dremel?
    8 Jan 2004
    What KVM do you use?
  6. woodshop
    woodshop UnSeenly
    14 Oct 2003
    Seconed.
    Tk-206i by TRENDnet
    AKA Genaric(sp?)
  7. ChegsJAR
    7 Sep 2003
    I use the cheap one of ebuyer
    Cheap one of ebuyer
    Quickfind code: 46424
    £18 and really good
  8. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    With a good KVM and good cables (more importaint) you should see no difference..
    -scoob8000
  9. ModMonkey
    ModMonkey Size 11 Carbon footprint
    22 Sep 2003
    i have a four port manual jobby that occasionally causes me problems. The main thing being that sometimes (and its reasonably rare) when i flip from one to the other, the new screen will appear but the mouse and keyboard will not work.
    I'd love to see a USB mouse and keyboard option on these. I'm sure they'd be better for switching too and fro
  10. cysus
    cysus What's a Dremel?
    14 Apr 2004
    Most KMV switches cause no problems because they are manually switching and have little to do with the connection. Some of the other KMV switches, the ones that have automatic switching or switch by a combination of keys on the KB, do cause some problems. The one I have makes the maximum fps 30.
  11. biff
    8 Jan 2004
    So manual is the way to go.
  12. aaronrkelly
    aaronrkelly What's a Dremel?
    1 Jan 2004
    I have a automatic switching one it is does not affect my FPS. One monitor you may not notice the difference with or without a KVM but I run a pair of identical Sony 17" LCDS. After connected the KVM switch to the second monitor I have noticed a little "fuzziness" with smaller text at 1280x1024. Also the color is a little off. Displaying an image the difference will not be visable but put the same image on both monitor and I have noticed blues look a little greyer. The functionality you will gain will outweight any difference.
  13. tomd
    tomd What's a Dremel?
    2 Feb 2003
    I have a cheap trendnet one as well (was about $25), and it works great, kinda fugly cuz it has cables coming out of each side of the box, but not a big deal... It has both a button and key combo to switch, no probs with gaming at all, i run HL2 and whatnot w/ my 17" LCD (analog)....and with my Logitech mx duo.
  14. Draxin
    Draxin Seeker of Photons
    29 Nov 2001
    do keep in mind that alot of KVM switches have a max resolution that they will work with.
  15. Tim S
    Tim S OG
    8 Nov 2001
    I run a KVM, it's fine and I don't see any degredation in quality on the screen, which is a bonus. There are said to be drops in quality of the output, but I'm not seeing a great deal of them at the moment, so all is good for me.
