Other Question about Lite-Coining
Discussion in 'General' started by TheGreatSatan, 25 Mar 2014.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    I just bought the Radeon 8990. I'm gonna have one of my coining friends try the card out to see how well it mines, since it destroys the 7990.
    http://gpuboss.com/gpus/Radeon-HD-8990-vs-Radeon-HD-7990
    He said that the card's have to be already in the coining system so they know the profile for it, and the 8990 isn't. What's he talking about?
  2. veryevil
    veryevil Well-Known Member
    14 Aug 2005
    The clock setting need to be tweaked for the best output. The profiles are just existing settings that have been found to work well with a card.
  3. TheMadDutchDude
    23 Aug 2013
    8990? I've never heard of that before but sure. I'm guessing it's the same as a 7990 under the hood so that's easy enough to program.
    One word of advice, make sure your fan is at 100% constantly. Seriously. I'd highly recommend loading it under Furmark with maximum settings for a bit first to find out maximum temperatures. Those are hot running cards.
    Can you confirm if it has the same amount of shaders as a 7990? If it is, it's really simple to figure out what's best for it. If you need a hand with creating a batch file, shoot me a PM. I'll help you.
    Also, try overclocking it. I overclocked my 5850s from 765MHz to 925MHz and the KH/s went up by 30%.
  4. TaRkA DaHl
    TaRkA DaHl New Member
    15 Mar 2011
    Depends if you want to ruin it within a month, personally I would see what it can comfortably run at whilst keeping decent temps. 100% fan speed will burn the motor out quick quickly, 75-80 will likely suffice.
  5. TheMadDutchDude
    23 Aug 2013
    I think they're okay to last a bit longer than a month. I've had a few HD 5850s running at 100% load for at least three months with 100% fan speeds. They're still absolutely fine. :)
    Either way, the card could run cool for all we know. Just let us know how you get on! :)
  6. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    i wouldnt bother as litecoin difficulty has gone up 100% in the last month and it isnt worth it anymore, IMO
    BTW a HD8990 is just a rebranded 7990, clocks at 1000/1500 will yield good results thats what mine are running and you should be about to drop the vcore to 1.1v or so, 1.2v is stock.
    and it will get HOT
  7. jinq-sea
    15 Oct 2012
    it's gone up by 100%? Wow!
  8. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    Well it's had no impact on mining if it has at least from my end, I'm still getting the same hash rates I was before on the 290x
    Sent from my GT-I9505 using Tapatalk
  9. TheMadDutchDude
    23 Aug 2013
    You will still get the same hash rates, just not the same payout.
    Kirk is right, it has almost gone up that much. It was at 3000 not too long ago and now hovers between 5400 and 5800.
  10. kirk46
    9 Jun 2012
    Yep indeed its bad unless u have loads of cards....
  11. jinq-sea
    15 Oct 2012
    To be honest, I dabbled for a day or two and then decided that I couldn't be bothered, particularly to increasing difficulty and decreasing US$/LTC exchange rate.
  12. TheMadDutchDude
    23 Aug 2013
    That's why I am getting rid of my set up. I only had 2200KH/s but I was seeing a £1 (ish) return per 24 hours after electricity was paid for. No thanks. I'd rather sell up and cut my losses. LOL.
  13. rollo
    rollo Well-Known Member
    16 May 2008
    If you have to pay your own electric its never been really worth while.
  14. lysaer
    15 May 2010
    That's not true, when litecoin was at $30 it was easily worth it, it needs to be at least $24 with a 10 grand hardware layout and it makes a fair profit
  15. jinq-sea
    15 Oct 2012
    It's now at a point, as I see it, where the actual costs of procuring hardware and powering it make it unprofitable. However - if you want to do it for fun, go for it! :)
  16. TheMadDutchDude
    23 Aug 2013
    If you intend to do it for a long time, it may end up being worth it if you hold on to the coins and play the waiting game whilst hoping that the coin you're mining goes up in value.
    There are obviously other alternatives to buying GPUs, such as ASIC scrypt (for LTC etc.) miners which produce tenfold the amount of power than a GPU could and use far less wattage too. They produce (at the moment) around 2 LTC a day and only use 160w/h to do it. They;re still in the design process though and will cost around £1200 to purchase (expected).
    It would cost 50p (ish) to run and it will give you roughly £16 to £20 worths of LTC back per day.
  17. TheGreatSatan
    5 Aug 2005
    The card is not for coining. I was just gonna have him test the hash rate and stop. Just for curiosity sake.
    It's gong in my gaming machine, for gaming and that's all
  18. TheMadDutchDude
    23 Aug 2013
    It would pull what a 1GHz 7990 would pull. There's no point blasting it and then stopping after two minutes. :)
    With it's slight OC, it you're probably looking at 1400-1425KH/s.
