Cases Question about Mid tower quality case
Discussion in 'Hardware' started by Edde, 8 May 2012.
  1. Edde
    Edde What's a Dremel?
    17 Apr 2012
    Hello all. 2 weeks and I am not decided about which computer case should I buy. My system will be LGA 1155 Intel DZ68BC, AMD SAPHIRE 7970, 16 gigs of Kingston HyperX RAM, Corsair HX 850 power supply and only 3 hhds. I am not an overclocker. I use everything in default mode.
    I like the clean look, but the clean Computer cases I saw on the market I have not seen quality in material that are built or they are enormous in size. I wanted a decent mid tower, visually clean (Apple style) and with quality steel with less chance of rust. What tips would you give me? I can't find aluminiun cases anymore in my country. :(
    I liked these models (though the visual not be clean), just the corsair has clean look is great but still I liked the corsair.
    1) Corsair Graphite Series 600TM ATX Case ( very good clean appearence but is it big?? Or have vibration on the sides?)
    2) RAIDMAX Helios ATX-819WB Black Steel ( I know this is not clean, but I love the appearence, it have a good iron, good quality?) http://www.newegg.com/Product/Produ...ark=&IsFeedbackTab=true&Page=3#scrollFullInfo
    3) http://www.newegg.com/Product/Product.aspx?Item=N82E16811119194 ( I don't really like the appearence, but seems very solid and more efficient air flow than Corsair 600TM ?)
    not taking into consideration the price. which one are the best for a mid tower computer?
    Please, I need sugestions about the ones that really cool inside and no noise and that have dusty filters and etc...
    Thank you in advance.
  2. Edde
    17 Apr 2012
  3. murraynt
    murraynt Modder
    6 Jun 2009
    What about the fractal R3 or Arc?
  4. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    +1 to murraynt's suggestion
    Either that or some sort of Lian Li case, I love the V1000 case, they made, odd design, but bloody awesome case and I got one for £35inc postage :D
  5. Ljs
    Ljs Modder
    4 Sep 2009
    If you can get your hands on one of these, you should. They sound exactly like what you want.
  6. Darkshneider
    Darkshneider What's a Dremel?
    10 Aug 2008
    I recently bought the Corsair Graphite Series 600T in white... Nice room, nice looking and it comes with clear and mesh window panel. +1 on it!
  7. Edde
    17 Apr 2012
    Hello, thank you for the sugestions. :)
    The fractal R3 or Arc don't have here in my country ( I don't know why). So...
    Rest Cooler master and Corsair models.
  8. Edde
    17 Apr 2012
  9. murraynt
    murraynt Modder
    6 Jun 2009
    Can you get the 550D?
  10. Edde
    17 Apr 2012
    I saw the 55OD and it is a really good case, very well made. I like it. But don't have in my country. :(
    THank you for all replies
    Here we have only: Cooler master Silencio 550
    Corsair Carbide Series 300R Black Steel
    someone could tell if the 300R comes with front filter?
    or Corsair Carbide Series 500R
    And the Corsair Graphite 600TM ( but is too big in depth and I dont have room for it) 3-4 inches makes a lot of difference for me.
    THank you for all.
  11. murraynt
    murraynt Modder
    6 Jun 2009
    My choice would be the 500R
    Where do you live anyways?
  12. Edde
    17 Apr 2012
    Hello Murraunt.
    I live in South America - Brazil
  13. murraynt
    murraynt Modder
    6 Jun 2009
    Ohh wow :blush:
    Well Welcome to Bit-Tech :p
  14. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Lian Li A05NB?
  15. Edde
    17 Apr 2012
    Hello Murraynt, thank you so much! :) You are very in kind.
    And what about you? Hugs
    Hello, mars-bar-man. This one is a mini tower, so small and warm inside for my system, thank you anyway.
  16. mars-bar-man
    17 Apr 2009
    If you're not overclocking the case will handle the heat fine. The small size of the case means stronger air flow and isn't lost on empty space.
    I've had a very 'hot' system in an a05nb before and it's stayed relatively cool.
  17. Edde
    17 Apr 2012
    Hello, mars-bar-man. Thank you again. DO you think this kind of case you sugest fits a system like the one I described ? If yes, So can I use a Cooler Master Silencio too? :D
    Since I am not an overclocker man I only worried about this videocard, people on foruns says this video card is a little warm.
    Thank you again.
  18. Ollie1807
    Ollie1807 What's a Dremel?
    12 Apr 2012
  19. Parge
    16 Jul 2010
