Watercooling Question about radiator inlets
Discussion in 'Hardware' started by Parge, 26 Apr 2012.
  1. Parge
    16 Jul 2010
    Quick question from those in the know:
    I have two EK 240 XTX rads coming. They have 4x G/4 fittings on the end, but also, another one on the other end that is labelled as fill/drain port as per the pic below.
    Question is: can this be used as a fluid inlet too?
    Reason I ask is because the block sits in front of my bay res, and if so, I can just pipe fluid straight in.
  2. feathers
    feathers Minimodder
    11 Apr 2009
    One would imagine so. Thought: If the hole is underneath it become a drain port. If it's on top it becomes a fill port.
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Would you only use one of the others as the outlet? As then you'd probably only be using half the rad...
  4. Big Elf
    23 Apr 2009
    Pete is right. The end port is described as a fill/bleed/drain port and unless the rad was a cross flow type it wouldn't be effective.
  5. asura
    asura jack of all trades
    22 Apr 2009
    +1
    To use that port and get the most out of your radiator, you'd need to use two ports on the other end (one from each side) and join them together with a Y connector or a manifold.
  6. Bloody_Pete
    11 Aug 2008
    Which is unlikely given the price...
  7. Big Elf
    23 Apr 2009
    It's actually a very good rad. If I were buying new rads now it'd be a toss up between these and the Alphacool UT60. I just like the idea of all copper rads.
  8. Bloody_Pete
    11 Aug 2008
    Oh no, I never said it was bad, just crossflow takes a load more engineering and cost :)
