Question about T.I.M. removal substances.
Discussion in 'Hardware' started by Xen0phobiak, 2 May 2004.
  1. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    Would a tim remover such as the akasa one, turps or white spirit damage hardware is immersed for a short length of time (30 secs or so). I am considering changing the hsf on my radeon and have heard about people pulling off the top of the r300 core. I'm thinking about heating the card up, removing the clips, giving the hsf a gentle tug, and if it doesnt come off quickly immersing it/carefully applying something to soften the t.i.m, would this damage the core/pcb if only a short exposure?
  2. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    I had no problems removing the stock heatsink on my radeon 9700 pro. my card was warm to start with because i was playing games before i changed the heatsink. i dunno if the stuff your talking about will cause any problems
  3. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    try and heat up the card with a hair dryer this will heat up the pad and let you remove the HSF.
