Modding Question bout a ClearPC case
Discussion in 'Modding' started by Morphine, 28 Feb 2002.
  1. Morphine
    Morphine weeee!
    23 Feb 2002
    Ok, one question before i go out and buy this stuff. When i get my clearpc case *drooool* i was wondering if vinyl dye works on it? I'm going for a blue themed case and i might paint front & back of case blue but in the macro black article the guy says that you mus be veeery cautious with paint as spiderwebbing will occur :( i dot want to take the chance of that and do any of you guys know of any other options for painting acrylic? I would really apreciate some help. I'm thinking bout making MacroBloo :p becuase that case he made was an inspiration for me.but i just need silver window tint or whatever he used on his case along with black tint. where can i buy this though? Not mapplin's or whatever :p i live in the states. I might be able to find this stuff if i ask around but i really really reallywould appreciat help on the painting issue.
    (p.s. - I want to thank all the guys here. You're all very helpful and a comic relief :D )
  2. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    I'm pretty sure macro used paint not dye, you should go back and read his articles and the threads tht go with them. I'm pretty sure that question came up in one of them.
  3. cderalow
    cderalow bondage master!
    23 Jan 2002
    macro painted the inside of the case... i don't think vinyl dye would work on acrylic because of the surface type... though i may be wrong.... in any case (no pun intended)... i'd paint the inside... just do light layers... should be fine
  4. Maedhroz
    Maedhroz What's a Dremel?
    22 Jan 2002
    get the window tint at pep boys or any auto store.
  5. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    i cant find the mirror tint either. ive found limo black but no mirror stuff. it is illegal in my state though, that might be why.
  6. tk421
    tk421 Idiot.
    15 Jan 2002
    ya up north you wont be able to find the solar stuff... but if youve got a friend in florida or alabama, its in every pep boys down there.god i miss orlando.
  7. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
  8. linear
    linear Minimodder
    5 Oct 2001
    Yes!
    Vinyl dye does work quite well on acrylic (I haven't tested polycarbonate, so make sure you know your material). But be aware you can order colored acrylic parts for the clearPC. Have you ordered it yet?
  9. bistro
    bistro What's a Dremel?
    21 Jan 2002
    You can check with Clear-View perhaps for parts.
    Be careful with choosing the window film --most mirrored films I've seen max out at 22% (will allow only 22% of the light in--or light out as in this case). Have seen in the past a few that go up to 35%. Not sure how much percentage of light emission a neon-lit case needs to look good. (Linear?)
  10. Morphine
    Morphine weeee!
    23 Feb 2002
    W00T!!!!!!! YEEEHAAAAAAAA!!!!!!!!!!!
    HAHAHAHAHAHA YES YES YES YES!!! Sorry I'm a little overjoyed!:D I just found EXACTLY what i wanted on ebay. One way mirror window tint. So... I'll use the vinyl stuff on the front and back of the case and then apply this stuff to the sides and top!! Add in some stealthed drives and Mmmmmmmm..... :D This is gonna be my big pimpin' comp at LANs! WOW big blue and mirror comp that turns see through whe its on! ooohhh. Dang too bad the state of Illinois limits the amount of hours a 14 year old can work :mad: gonna take me till next fall to finish this comp. Ooh can't wait!
  11. eddie_dane
    31 Jan 2002
    From Macro's article....
    "This is true of both the chrome and black films. The black film has a light transmission value of 20%."
    http://bit-tech.net/article/63/7
  12. Boggy
    Boggy What's a Dremel?
    3 Jan 2002
    it should look very good!
    post some pics of your finished case!
  13. eddie_dane
    31 Jan 2002
    yes, as much as we like talking about your project we neeeeeeed eye candy :D
  14. Morphine
    Morphine weeee!
    23 Feb 2002
    dang.... long time lft on this project
    I just figured out how long its gonna take me to get this comp done (well there is always stuff to mod ;) ) But then again... there is never enough money. :( I'll see boutordering case and geting all of it done in mid-summer-ih time and the comp will be dont sept-oct in the fall. I only make $6.15 an hour and the $1,800 I'm gnna need will take a while :p oh yeah by the way. My parents are friends of the local Harley-Davidson dealership owner! I'm gonna get some templates for a SWEET paint job. I'll post a little preveiw I'll make in photshop for ya guys.
