Electronics Question on LCD Display
Discussion in 'Modding' started by corvette, 19 Jun 2008.
  1. corvette
    corvette What's a Dremel?
    27 Nov 2001
  2. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    this is from this forum
    dont know if its the type of screen interface you need but i couldnt find much info about the screen
  3. bigal
    bigal Fetch n Execute
    8 Oct 2004
    It looks like a standard HD44780 display, 16x2 character with LED backlight, the pinout seems to be identical (first datasheet). 99% of character displays like this are hd44780 or at least are compatable (rip-offs basically). You can either hook this up to the parallel port as per normal, using just a printer cable, some wiring for the power to it (5v) - you may need a resistor for the backlight - look for a resistor near pins 15 or 16 (in series with). you will also need a potentiometer for the contrast adjustment.
    If you wish to connect it to USB or SERIAL you will need a controller IC - there are a couple about that use a PIC or AVR processor to take serial comms and output it to the LCD, it is not terribly hard and there is plenty of info about. If you want a cheap fix, try looking at LCD2USB for instance : http://www.harbaum.org/till/lcd2usb/index.shtml
    note that USB -> Parallel adaptors wont work as they immitate USB printing support and not an actual parallel port...
    Good luck,
    Alex
  4. corvette
    27 Nov 2001
    Do you no Where i can get a Wiring Diagram for the Parallel Port
    Thanks
  5. const_
    const_ What's a Dremel?
    15 Nov 2005
  6. dragon2309
    dragon2309 techie
    28 Jul 2006
  7. KID52
    KID52 Minimodder
    19 Aug 2007
