Education QUESTION: red LED through a green filter? What colour will it end up as?
Discussion in 'General' started by mookboy, 15 Nov 2008.
  1. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    I want to replace the dash bulbs in my car with LED's. Only ones I've got lying around are ultra bright red LEDs - but the speedo/rev counter clocks have a green film over the bulb housing.
    What colour would I end up with red LEDs' shining through a green film/filter?
    Thanks in advance!
  2. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    None.
  3. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    None... errr, so would it therefore be green?
  4. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    None as in no light; the green filter only lets green light through, the red LEDs have no green light.
    It doesn't work that perfectly in the real world but I reckon they'd be too dim to see.
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    It will be black.
  6. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    fiver on yellow and three pounds fifty on orangey blue
  7. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Depends what kind of Red but you're really only going to end up with some kind of black.
  8. Firehed
    15 Feb 2004
    This is correct, in theory. In practice, your filter probably won't block enough light transmission to be truly effective and really cause much of a transformation. When I hold a red gel up in front of my face, I get more of a red-tinted greyscale when looking at my monitor, with the redder parts of the screen being brightest. But part of that is your eyes internal white balance playing tricks on you. Parts of the screen that are pure blue or pure green go effectively black with the red gel in front of them; expect the reverse to also hold true if you've got a very rich green filter/gel in front of a red LED.
  9. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Why don't you remove the green film? :dremel:
  10. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Would mean taking the clocks out and taking them apart... CBA.
  11. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    Cant be that hard, there are walkthroughs online for my car (mazda 3) to do exactly that. You take off the red film and then can put in any color led. the blue ones look nice.
  12. Akava
    Akava Lurking...
    28 Jul 2007
    Oh why not just get hold of some green LED's? They're not exactly expensive or difficult to get hold of, thus negating any need to remove the film etc. :thumb:
  13. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    I think you'll see the red at least where it's close to an led, and the color will fade and dim through yellow/orange to black as you get further from the led, if the gaps are big enough. So it would kinda look like bad vomit or something like that!
    If this green layer is painted and can't be removed, then just get green or aqua leds. The green filter only wants to let green through, so any color other than green is reduced. You'd have to put more blue leds in there than the standard number of lights to get blue, or alot more red leds in to get red.
    If the green layer can be removed, take it out, choose whatever color leds you want, and be happy :thumb:
  14. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    get green leds, problem solved.
    they are cheap.
  15. Smilodon
    25 Mar 2003
    very bright green ones are actually pretty expensive. I'm sure some guy in china sell them dirt cheap on eBay, though.
  16. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Did it with the reds. Gonna go back and replace the MFA bulb with a bright white one so it's bright green. Looks a lot brighter in reality. Obviously. Kind of has that 'submarine under attack look' to it now.
