Cooling Question to TRUE users
Discussion in 'Hardware' started by SSN774, 31 Dec 2009.
  1. SSN774
    SSN774 What's a Dremel?
    29 Jul 2005
    Hi guys,
    I'm wondering how you clean this beauty? Do you use compressed air, cloths or something else. Mine got a lot of dust, so its time to make it like a new pcs.
  2. D-Cyph3r
    D-Cyph3r Gay for Yunosuke
    31 Aug 2008
    After lapping I rinsed mine under a tap, same as I did with dust-clogged rads. For quick drying nab your girlfriends/sisters/mums hair dryer. ;)
  3. SSN774
    29 Jul 2005
    I hope it wont get rust after bath ;)l
  4. D-Cyph3r
    31 Aug 2008
    Nah, the nickel plating does a wonderful job of preventing that. :D
  5. Pookeyhead
    30 Jan 2004
    I just use a artist's painting brush with long bristles, and powerful vacuum cleaner.
  6. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    What material is there to rust? There is no ferous metal in its construction.
  7. Teelzebub
    27 Nov 2009
    I remove the fans and use a small compressor to blow out the dust work's great
  8. SSN774
    29 Jul 2005
    True, but I dont have any.
    Thanks to all of you for help. After work I'll make it shine :)
    Happy New Year for all!!!
