Question: what slot is this? [pics]
Discussion in 'Hardware' started by k.a., 29 Jun 2003.
  1. k.a.
    k.a. What's a Dremel?
    4 Jun 2003
    My moms company is cleaning out some "old" hardware (like 24port switches =)))
    one of the things i got was this "broken" PC. its a Silicon Graphic 320 workstation
    It's "broken" since the display doens't show a picture (orange standby light doesn't turn green)
    Now, I want to figure out if its the graphiccard, the TFT.. the cable or whatever, the only problem is, that the hardware is a little different from the ordinary PC:
    what u see behind the rear-fan is the graphiccard (or at least part of it). It doenst have the standart VGA connection, neither the standart digital TFT connection.. but this odd coustom thing.
    thats another (crapy) pic (its left of the .. odd RAM and IDE connection)
    so... i just wanted to connect some old 2mb PCI graphiccard ...
    but:
    i guessed pci-32 & pci-64... though just why is the PCI-slot the wrong way around????
    and thats my main question: what kinda slot is that? .... and what is it for??
    i'ld be very gratefull if anyone could answer that question for me =)
  2. GT3_GOD
    GT3_GOD What's a Dremel?
    6 Nov 2001
    Wouldn't be willing to part with that silicon graphics case would you?
  3. RTT
    RTT #parp
    12 Mar 2001
    I'm fairly sure that the only thing that slot can be is 64bit PCI.
  4. k.a.
    4 Jun 2003
    well, i believe the long one is (the one with ultra2-SCSI controller)
    but the short one??
    edit: i kinda like the case =) bit small for my taste, but 1st i gotta see if i can get that thing working again
  5. penski
    penski BodMod
    29 Aug 2002
    CNR slot?
    *n
  6. Flax
    Flax What's a Dremel?
    24 Jun 2002
    The backwards PCI slot is probally an Advanced Communication Riser (ACR) slot.
  7. k.a.
    4 Jun 2003
    hm ACR sounds plausible when i look it up.. but... just what do i do with it???
  8. Cheese
    Cheese Doc
    6 Oct 2001
    Nothing, you could buy a modem for it if you wanted to...
    ...as for the TFT, Mashie has one, you can get a little box to convert its input to a normal VGA cable, I'm sure google will help you out ;)
    Rob.
  9. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    put a PCI card in backwards? that could be fun
  10. ajack
    ajack rox
    17 Apr 2003
    What kinda ram is that and how much is there?!
  11. Atomic
    Atomic Gerwaff
    6 May 2002
  12. RTT
    RTT #parp
    12 Mar 2001
    sos, thought you were on about the big one :p
    small one is ACR as already said :p
  13. k.a.
    4 Jun 2003
    @jack_ .. i have NO idea ;) one page i googled said 128 ECC-SDRAM, but that page also said dual-PII-350 and the one i got has dual-PII-500
    ... no idea
    @cheese
    this?? http://www.sgi.com/peripherals/displays/multilink/
    or something different (cheap??)
    modem.. hm.. got DSL =) and it's got pretty much everything onboard! (firewire, sound, s-video in and out, composide video in/out, also (dont know english word, they look like this [​IMG] for sound-in and out.. just kinda luxury!
    another question:
    the big slot (pci-64??), the one with the card in it, any chance i can get a graphic card for that? there's another free slot just unterneath the card
    or.. well.. thnx to u, i at least know i can use the display for something! but what about the rest of the PC? just a pile of 4 year old $12000 hardwaregarbage? or any of you know anything how i can get a (normal?) graphiccard in there?
  14. k.a.
    4 Jun 2003
    according to this page, its a 64-bit 3.3V signaling PCI Slot
    anyone know (or have??) an old graphiccard for me fitting? =)
  15. cderalow
    cderalow bondage master!
    23 Jan 2002
    nifty case
    and on a side note, it'd probably run farely well if it worked.... no idea what OS SGI systems use though.... but I bet you'd be surprised at what it could do
    and PII 500?????? :confused:
    was pretty sure PII stopped at 450 where there's PII/PIII variants...
  16. k.a.
    4 Jun 2003
    I'll check that again, but i'm pretty sure it said 500/512/something (mhz/L2/... ?)
    i guess i'ld wanna run it as Gameserver on LANs for example... dualPII is still more than enough for HL or UT or sorts.
    ... but i need some graphics first :)
  17. p3n
    p3n What's a Dremel?
    31 Jan 2002
    dual 500 mhz is enough for anthing ... a 32 player counterstrike server with 20 plugins might just use it all
    have you tried all the usual checks for a non-booting system ?
  18. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    know what kind of SCSI card that is? <droolz>
    -scoob8000
  19. k.a.
    4 Jun 2003
    well the problem is, that i don't even know if it boots. no speaker, didn't find anywhere to connect a speaker. there seems to be some HDD activity, but i don't know if its the normal power-on thing.. but i THINK its more than that.
    i got it connected and running, and i'll do a LANguard networkscan over the night. (when connected to switch, the switch-lights are on for connection).. though i dont know what ip it can be... so i'm scanning 192.168.0.1 - .255.255 to see if it's completly booted (though don't know if anything will show up if its booted, but on some errormessage.. =( )
    the reset-button works... at least the cd-rom makes this "regrab tray" kinda noise...
    any advice?
    BTW: i gotta admit, i was kinda.... blind. it DOES have a standart VGA connection onboard, but i overlooked it, assuming it was COM2. buuuut it doen't show anything either.
    main problem is lack of speaker =( just sooome kinda beeping would really help me out =(
    ps: didn't check what SCSI card it is.. probably because i have no idea what is good with SCSI anyway =P but i'll check tomorrow if scan doens't show anything when i can turn PC of
  20. Bruno_me
    30 Mar 2003
    I looked around on sgi's site, and found: this, the users manual. in troubleshooting, there is a thing about the power LED blinking, this may be of help...
