I'm considering building a cube style case but am just starting to get everything laid out, haven't quite got dimensions yet. What I'm wanting to do is have a 2 level case. The bottom would be all the hard drives, pump and rad for water cooling, cd roms, psu and then the top level have the mother board laid flat as if in a desktop case. I was thinking that the biggest concern would be heat but being water cooled and I'll probably have 3 120mm fans + whatever is in my power supply, that shouldn't be a problem. Now what I'm worried about is, I didn't want the case to be much bigger dimensions around than my motherboard(nf7-s) and didn't want the bottom to be much taller than the tallest component. I'm kinda worried about so much running there being so cramped and some interferance from my pump(Swiftech mcp600.) How far should I try to get the pump away from other components to be safe?
Use scetchup (if you know how to use it) and download the needed (or all) of the scetchup-components (a thread in the forums) BTW. have look at my project (link in sig.) for some insperation Good Luck
