Modding questions about relocate cd-rom eject switch and led
Discussion in 'Modding' started by Lineage, 24 Sep 2003.
  1. Lineage
    Lineage What's a Dremel?
    19 Sep 2003
    i had read Zapwizard's method of
    Re-wired DVD Activity LED and Eject switch -Guide
    and i have some question....
    1) can i connect my new switch and the switch in the cdrow with 2 wire at the same part of the switch, like gound to gound and power to power?
    2)can i connect the 5 volt to the white circle in the image?
    (dont know if the image will show up or not, in case it dont. its the big pin that just locate beside the main power suppy connectior and the pin zapwizard used)
  2. penski
    penski BodMod
    29 Aug 2002
    Moving to modding.
    *n
  3. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    wow.... first thread ive seen moved to modding :hehe: anyway.... i have rerouted my CD button to be the case badge -- so when you press in the case badge the drive opens (see my budget mod log in my sig :p )
  4. Guest-2808
    Guest-2808 Guest
    Not sure what you are getting at exactly Lineage, since your images don't work.
    If you mean can you wire two switches to the same points, then yes you can.
    MoJo
  5. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    uh, just connect the new switch in parallel with the old one, and conect the led in parallel also, though you can disconnect the old led though.
  6. pranks7er
    pranks7er mange tout
    25 Dec 2002
