Peripherals questions about USB C cables
Discussion in 'Hardware' started by silk186, 3 Jun 2020.
  1. silk186
    silk186 Derp
    1 Dec 2014
    I'm planning to order a new surge protector to remove daisy-chaining. This will require some new cable runs. This will be all USB type C and micro.
    The cables I'm concerned about is the C to C for a MacBook pro and second type C for OnePlus warp charger. Do these use regular type C cables or do I need to find specific cables?
    Will cable length impact charging? I've read the usb 3.1 doesn't like long runs.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    You want shorter cables, as the wattage those cables will be delivering longer ones will drop a huge amount of power!
  3. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    Dash chargers only work with the original 1+ cable as they charge at 4A , which would melt chinesium grade cables. Warp is even more amps.
  4. silk186
    silk186 Derp
    1 Dec 2014
    I did not realise these used different cables.
    I can keep the charging wire for the oneplus on my side of the table using the included cable.
    How long can a MacBook pro C to C charging cable be and are they also apple magic cables?
