Graphics QUICK! 3dfx query...
Discussion in 'Hardware' started by Ryszvaldo, 23 Jan 2006.
  1. Ryszvaldo
    Ryszvaldo Banned
    3 Jan 2005
    Just picked up a box of old bits and found a 3dfx voodoo card - it has a floppy type connector on and a 2nd vga input it looks like - I want it on my xp m/c to run a 2nd monitor - any idea of where to get the drivers?
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    You need an existing graphics output to run through that, since the older ones were "3D accelerators" and not video cards in their own right. You need to run a standard VGA d-sub into the input part, then connect the output to your monitor. Not much good for multiple monitors :(
    If you still want drivers, a quick Google search revealed this.
    By the way, the floppy type connector is for... SLI! It was originally implemented by 3dfx but when they were acquired by NVIDIA the technology was resurrected.
  3. Ryszvaldo
    Ryszvaldo Banned
    3 Jan 2005
    Cheers hitman , SLI would be nice but I think that my nice 9500 pro might be more powerful than the card... seems like a no go then... ho-hum - back to the drawing board...
  4. customh
    customh conflagration.
    22 Oct 2005
    So all those cards with that floppy connector are what? "SLi" capable? again, just curious
  5. hitman012
    6 May 2005
    Yeah, the Voodoos were capable of SLI, which, back then, stood for "scan line interleave". Obviously, it wasn't as advanced as what we understand SLI to be nowadays - each card simply rendered a line in turn, as opposed to the AFR and load balancing techniques of the modern implementation.
    It cost a pretty penny then, too :blah:
  6. Ryszvaldo
    Ryszvaldo Banned
    3 Jan 2005
    wanna buy one? lol
  7. customh
    22 Oct 2005
    But if my card thats old has a floppy connector it is "SLi capable"?
  8. Krikkit
    21 Jan 2003
    No, it just needs extra power, and gets it from a floppy connector.
    The SLI cards were only specific brands - you could have the equivalent of an Ati there...
  9. hitman012
    6 May 2005
    No - he was referring to a floppy-style data connector, not the power plug. See this picture, it should clear things up :)
  10. customh
    22 Oct 2005
    So whats it do is still dont have my answer
  11. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    You can get two of those old cards to work together, much like the modern SLI system. In fact, as nVidia bought 3Dfx, I wouldn't be surprised if there's some of the old SLI tech in the new SLI.
  12. hitman012
    6 May 2005
    I think people have made it pretty clear that old Voodoo cards with a floppy-style data connector were capable of an old version of SLI. What more do you need to know? Does your card have a different connector on it?
  13. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Its not hard to re-wire a floppy connector to work as the SLI bridge tbh, just needs a few wires switching over on 1 of the cards.
    Connect up the graphics card to the "master" and away you go...
    Performance is quite good tbh, can run Original UT @ 1024*768 at ~ 65-70 fps, using Glide. Pretty impressive for 2 12mb cards tbh lol
  14. Guest-16
    Guest-16 Guest
    I dont know if the original Voodoo's were SLI capable, but the Voodoo 2's definately were. A 9500pro will be about a million times faster and will actually have drivers you can use.
  15. Highland3r
    25 Jul 2003
    You need to run a graphics card with these voodoo's anyway, since they're only 3d accelerators...
    If you hook up a 9500pro (for example) and 2 voodoo's in SLI they'll "pass through" D3D/OpenGL without processing, but will accelerate any glide games.
    This way, you can play your favourite D3D game, and switch straight over to a glide enabled title without faffing about with cards...
    The only issue is the lack of DVI on the voodoo's...
  16. Ryszvaldo
    Ryszvaldo Banned
    3 Jan 2005
    thanks for your help peeps - just ordered a dvi to vga adapter from fleabay for £4 for my dual array - see if I can make that back by auctioning the voodoo off!
  17. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    You won't get anything for them mate. I had 3 Voodoo 2 cards a while ago, and I gave them away for the cost of postage.
  18. customh
    22 Oct 2005
    So only the voodoo's had the capability, not any card with this style connector?
