Build Advice Quick check on a build
Discussion in 'Hardware' started by KeTZz, 28 Jul 2012.
  1. KeTZz
    KeTZz Minimodder
    25 Apr 2009
  2. KeTZz
    KeTZz Minimodder
    25 Apr 2009
    Sorry forgot to add i was also thinking of this cpu Intel Core i3 2120 3.3GHz Socket 1155 3MB L3 Cache but not sure what would be better for gaming and stuff ?
    Cheers
  3. Weebob
    Weebob What's a Dremel?
    23 Jul 2012
    Says the cart is empty I'm afraid
  4. KeTZz
    KeTZz Minimodder
    25 Apr 2009
  5. KeTZz
    KeTZz Minimodder
    25 Apr 2009
    Sorry im being a noob lol not sure how to make it bigger ether :(
  6. Elton
    23 Jan 2009
    Could you just post up the specs? :)
  7. KeTZz
    KeTZz Minimodder
    25 Apr 2009
    Microsoft Windows 7 Home Premium w/SP1 £71.98
    Kingston 8GB (2x4GB) DDR3 1600MHz HyperX XMP Memory Kit CL9 1.65V £36.38
    Seagate 1TB 3.5" Barracuda SATA-III 6Gb/s Hard Drive - 7200RPM 32MB Cache £65.00
    AMD FX-6 6100 Black Edition 6 Core 3.3Ghz Socket AM3+ 8MB L3 Cache Retail Boxed Processor £103.64
    Arctic Cooling Freezer 7 Pro rev 2 Socket 775, 1156, 1155, 1366, AM2, AM3 Heatpipe CPU Cooler £15.44
    Gigabyte HD 7850 OC Windforce X2 975MHz 4800MHz 2GB GDDR5 Dual DVI HDMI Dual Mini DisplayPort PCI-E Graphics Card £189.16
    (free accessory) AMD Dirt3 Showdown Download Coupon £0.00
    Coolermaster Centurion 5 II SPECIAL EDITION Case with Red Interior - With Coolermaster 650W GX PSU £90.63
    Sony AD-5280S-0B 24x DVD±RW & DL SATA Optical Drive - OEM Black £13.35
    Gigabyte GA-970A-D3 Socket AM3+ 8 Channel Audio ATX Motherboard £65.06
    Total £650.64
  8. Weebob
    23 Jul 2012
    As a hard core AMD fan I went with a similar build, the processor is fine if you are willing to overclock it to bring it up to Intel's stock. They are also power hungry.
    I went for a asrock 970 extreme 4, for the three full length pcie slots
    As much as it pains me. A i3 maybe a better choice, allowing you to move to a i5 as a easy upgrade.
    My AMDfx build cost £300ish,. For the money your spending I would lower the spend on the graphics card (AMD hd 6870 offer good bang for buck) and get a i5 in there.
  9. Elton
    23 Jan 2009
    Not a bad build actually. Getting an LGA1155 build though might be better for IPC performance but no quad core is a shame.
  10. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Im leaving the build critique to others. Don't use Ebuyer customer support is terrible.
  11. KeTZz
    KeTZz Minimodder
    25 Apr 2009
    Iv'e used ebuyer loads and never had any problems :)
  12. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    hmmm if your gonna overclock id look for something with more solid VRM cause bulldozer will push them to the limit...for a tad bit more you can get a much more capable motherboard with a 990fx chipset aswell
    Gigabyte GA-990XA-D3 990FX Socket AM3+ 8 Channel Audio ATX Motherboard
    its basically the 990fx version of the one you chose...
    such as that
  13. Weebob
    23 Jul 2012
    A mate of mine bought a small keyboard for a htpc. They sent him two sandwich toastie markers.....
    Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk 2
  14. KeTZz
    KeTZz Minimodder
    25 Apr 2009
    Think iv'e changed my mind lol how is this looking now iv'e come down with the gfx card to a 6870 and gone with a better processor :) think he's only gaming on 22" monitor anyway and a 7850 is overkill imo :)
    Will this handle games like sc2 wow and diablo3 on full settings ?
    I wont be overclocking it at all :)
    Gigabyte GA-Z68AP-D3 Z68 Socket 1155 8 Channel Audio ATX Motherboard £71.57
    (free accessory) Gigabyte 16GB USB Promotion £0.00
    XFX HD 6870 900MHz 1GB GDDR5 Dual DVI Dual Mini DisplayPort HDMI PCI-E Graphics Card £128.76
    Intel Core i5 2500 3.3GHz Socket 1155 6MB Cache Retail Boxed Processor £159.33
    Total £652.44
  15. Xahl
    Xahl Your mum's a Dremel
    18 Mar 2011
    scan would ofc be cheaper, free delivery for bittech members f t w.
  16. Elton
    23 Jan 2009
    For the price of the i5 2500, how much of a stretch is it to get a 2500k? Because honestly, might as well have a processor that can overclock the beans out of it.
    Overall, not a bad build, although I'd settle for a HD6850 on the pure basis that it's much cheaper. Also if you're willing to wait I do recall that the 660Ti might be coming out soon leading to price drops on more powerful cards. But if you must want a build now. It's a relatively solid build and you can run pretty much anything on high/full settings provided you have a resolution of 1650x1050. At 1920x1080 you might have to scale back a bit.
  17. KeTZz
    KeTZz Minimodder
    25 Apr 2009
