Build Advice quick compatibility check
Discussion in 'Hardware' started by sixfootsideburns, 14 Feb 2009.
  1. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    So i'm building a scratch made file server and i plan to make it quite small, possibly passive cooled, and these are some of the parts I plan to order here in the next few days. Just wanted to get someone else to do a quick compatibility check before i make a big "woopsy" and spend money on something i cant use :D
    mobo
    PSU
    memory
    CPU
    hard drive
    and I am not using any ROMs and the LCD i plan on using is USB connections so i'm fine on that,
    thanks in advance for the help :)
    sideburns
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Mobo and CPU are fine, but you could down grade the ram, aslong as its a well know brand, just go cheap.
  3. sixfootsideburns
    6 Feb 2009
    alright great, thanks for the advice mate :)
    what do you think about this for RAM instead then? I guess I get nervous about going cheap but the word is its ok on ram then i guess it doesn't much matter
  4. sixfootsideburns
    6 Feb 2009
    my other question is that do you think ill really need that duel-core CPU i listed above or would this be ok instead?
    I really am only building this to host files for myself and my house, sooo
  5. Burnout21
    9 Sep 2005
    yeah go as cheap as possible for the job considering its just yourself.
    Hell with the board you picked why not make it a HTPC aswell. The job your asking it to do an Atom based ITX would be fine.
  6. sixfootsideburns
    6 Feb 2009
    well a big thing for me is the built in wifi would be fantastic and i am planning to have it be something of a HTPC sort of rig when i want one. haha
    what do you think about the CPU though? should i even bother with dual-core?
  7. sixfootsideburns
    6 Feb 2009
    so nobody has any advice on duel-core vs. mono-core?
  8. Burnout21
    9 Sep 2005
    cost really, duals are so cheap now there isn't a reason dont too.
  9. sixfootsideburns
    6 Feb 2009
    just what i wanted to hear, thanks a lot mate :)
