I'm, slowly, getting my watercooling back up and running. I've got 2 120mm fans A panaflo with a model number fba12g12m and a Titan aluminum jobie. My question is which one will be more quiet/give the best performance? The one that looses out will become the shroud for the other pulling through a BIX. On the noise issue, I plan on 7V modding anyway, but which has the least whine to it?
Quick Googlorise gives.... Panaflo Nominal Speed: 2100 RPM Maximum Air Flow: 2.45 m3/min or 86.5 CFM Noise: 35.5 dB-A Titan Rotation Speed: 3000 RPM Acoustical Noise: 26dB(A) Airflow: 37 CFM Thus making the Titan quieter but the panaflo more efficnent [NOTE: As you didnt give a model # for the titan, i took it off the first random review I found of a Titan fan. (Panaflo was taken directly from their site)]
The Titan 120mm's push 79cfm (at least I hope they do...ordering some tomorrow and the site states 79cfm.... )
Thanks for the response. The titan is model # tfd-12025h12c Thanks for the specifics j4ck. I really should have just done some google work but I was feeling lazy. The Titan fans are only $12 and seems easier to disassemble than the Panaflo so I guess it gets it's guts ripped out.
Here's the official specs for that fan. Rated Speed : 2200RPM Max Air Flow : 84.76CFM Noise Level : < 39dBA So this makes the Panaflo better in each situation
Panaflo makes great quality fans...and they have never let me down. Even putting them on my 0-12v controller didnt stop them. The noise isnt bad either.
Thanks Cheebs It seems that not only is using a fan as a shroud a bad thing but using a shroud in general is not so great. I guess that means I get to use the Titan for another project. The only thing that worries me about the Panaflo is that its motor is so large there will be a bigger dead spot than the Titan. I'll have to just try out both and see what happens. maybe I'll do my own testing of the difference a shroud makes too.
if you read the thread you'll see that a shroud is good, it's just that a fanbody is so bad it's worse than no shroud.....
