Cooling Quick Fass-o-matic question
Discussion in 'Hardware' started by Shadowed_fury, 23 Nov 2005.
  1. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Bare in mind i'm using 1/2 tubing, can I use the ports on the bottom for inlet/outlet. Like;
    |_inlet__LED__outlet_|
    I'm thinking doing it like this is going to cause air-bubbles, and the pump sucking down the same water.
    Would I be better trying to find a way to use a side inlet, and bottom outlet?
    Or will this work alright?
  2. AWACS
    AWACS What's a Dremel?
    10 Jun 2005
    you could add a small pipe to the side where water streams into the rez... though if both are under water then there is no chance of airbubbles
  3. Nexxo
    23 Oct 2001
    I have an 3/4" outlet in the bottom of my aquatube sucking water down to the pump inlet, and no bubbles. You'll be fine.
  4. Shadowed_fury
    21 Nov 2003
    Yeah, what I ment is, will it still act as an airtrap? :(
    I don't wanna see what happened with Leeums first time round ;)
  5. AWACS
    10 Jun 2005
    hmmm... lemme see... yes... but make sure you have plenty of water in it
  6. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Go with what works best for the tubing in your setup. Any combination will work, just takes a bit of work bleeding the bubbles out :thumb:
  7. Shadowed_fury
    21 Nov 2003
    Thats what I wanted to hear, thanks mate! :)
  8. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    That will work... how do I know, because i'm looking at one right now!
    1/2" tubing, |_inlet__LED__outlet_| (same as you described), D4 pump.
    No air bubbles, no problem... although you will have to bleed it properly first.
