Modding quick led question
Discussion in 'Modding' started by r3Q, 25 Sep 2003.
  1. r3Q
    r3Q Minimodder
    31 Jul 2002
    alright guys,
    i was just wondering, in lamens terms... if i were to get a molex, and splice off the 12v line, how many of THESE could i hook up?
    1-what resistor should i use
    2-a diagram of how they should be soldered (just a picture, none of that crazy electronic diagram stuff) =P
    sorry, im a bit of a newb at electricity.. as long as somone tells me what goes where, i can handle myself.
    thanks a ton guys. :lol:
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Technically, the limit depends on how strong your power supply is.
    It'd help if you told us what application these were to be used in, since there's about a zillion different combonations you could use.
    If you were to wire them in series (diagram 1), then you might be able to get away with 4 LEDs, no resistor. Most likely though, you'll need to go with 3 LEDs and a ((12-10.8)/.02 = 60) 56 or 68 ohm resistor.
    In parallel (diagram 2a), it really depends on just how many LEDs you want to use. Each LED will add another 20mA to the equation ((supply voltage - forward) / total current = ohms needed, in your case (12-3.6)/total number of LEDs*.02 = ohms). Conversely, you could figure out the resistenace needed for just 1 LED (390 or 470 ohms in your case), then wire 1 LED with 1 resistor, then string a bunch of them together in parallel (diagram 2b)
    The finally, there's series-parallel (diagram 3), in which you find the most LEDs you can use in series, with the appropriate resistor added, and connect the strings in parallel.
    Diagram 1:
    Code:
    +12v - |>| - |>| - |>|- v^v^v - GND
    Diagram 2:
    Code:
    +12v - v^v^v - | - | - | - | - |
                   V   V   V   V   V
    GND - -  - - - | - | - | - | - |
    Diagram 2b:
    Code:
    +12v - - - - - | - | - | - | - |
                   V   V   V   V   V
    Diagram 3:
    Code:
                   V   V   V   V   V
                   V   V   V   V   V
                   V   V   V   V   V
    That damn well better be comprehensive enough.
  3. r3Q
    r3Q Minimodder
    31 Jul 2002
    whypick1 -
    thanks so much. im really a newb at this, im gonna put some into my computer with my CCFL, and i wanted to know if i could hook them up to my PSU... probally around 400w. ill stik to 3 leds + resistor.... also, can i do that with a car? a car battery is 12v, and there is a lot of juice there. could i just hook 1 resistor up to the 12v and string a bunch of leds onto it?that would be sweet... thanks guys! :clap:
    this sounds easy to me ;)
