Electronics Quick PIC questions
Discussion in 'Modding' started by ch424, 28 Jun 2005.
  1. ch424
    ch424 Design Warrior
    26 May 2004
    Hi,
    I couldn't find this on google, so two quick questions:
    1. If you have 0x00 in a reg, then do
    decf reg,f
    (therefore reg = 0xFF) does the carry flag get set?
    2. If you have 0x00 in the working register and 0x00 in a reg, then you do
    subwf reg,f
    will the carry flag get set?
    I'm getting otherwise inexplicable behaviour from the MPLAB simulator and a 16F84.
    Thanks for any help
    ch424
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    1. No
    2. Yes
  3. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    all in the data sheets.
  4. SteveyG
    23 Nov 2002
    Indeed. If you're getting "inexplicable behaviour" you've mis-read or not read something ;)
  5. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    i wouldn't go that far, the sim does have some limitations (thou most seam documented... now) but its often someone does something silly (like let MCLR float) and can't figure out why their code isn't behaving properly.
    The art of PIC programming is reading the datasheets. Multipule monitors kick arse for this! (or a laptop or something to read the datasheets (product line + device datasheet).
  6. SteveyG
    23 Nov 2002
    Yeah, but he said the sim AND his PIC... :)
    A laser printer is also useful for those datasheets :)
  7. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    I wouldnt try one for the Mid-Range MCU Family Reference manual though :p
    Maybe sections, but not the whole thing.
  8. ch424
    26 May 2004
    Ah, great thanks - I hadn't thought of checking the actual datasheet! QUOTE: "2: Yes" explains why I'm getting these problems! I'll have to re-write that bit of the program then!
    thanks again
    ch424
  9. ch424
    26 May 2004
  10. SteveyG
    23 Nov 2002
    It's just due to the way you subtract 2's compliment numbers.
    ConKbot.. I have the midrange manual, and 16 of the PIC datasheets for 10F, 12F, 16F and 18F series printed out. :p:)
  11. TheAnimus
    TheAnimus Banned
    25 Dec 2003
  12. ConKbot of Doom
    2 Jul 2003
    Thats what I should have done while still in school... :duh:
  13. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    multipule monitors kick arse!
