Electronics Quick question about USB nokia charger
Discussion in 'Modding' started by pr0xZen, 8 Nov 2004.
  1. pr0xZen
    pr0xZen What's a Dremel?
    5 Nov 2004
    I want to make an USB nokia charger for my 7650. The usb port outputs 5V, max 500mA. The charger that came with the phone says it outputs 5,7V 800mA. Seeing that both amps and voltage is a tad LOWER than the that of the carger - would the possible malfunction ruin my cell, or just *not work* ?
  2. Renko
    Renko What's a Dremel?
    19 Feb 2002
    You could ruin your usb port by trying to draw too much current. Chances are that the charger is rated at 800mA so that the phone can be charged as well as recieve/make calls. Hook up your multimeter and see what it draws on charge and when making calls or using other functions...
    Most lithium cells are 3.6V so a slightly lower voltage should not cause problems for charging of the cells.
  3. pr0xZen
    5 Nov 2004
    Ok. Yes, its a 3.6V li polymer battery. Honestly, I don't know where to measure this thing when charging. I obviously cannot measure at the phone, and the charger is a mean mofo when it comes to showing its guts. any ideas?
  4. star882
    star882 What's a Dremel?
    19 Mar 2003
    I have made a cable to power and charge my Dell Axim X30 from the USB port.
    The supplied PSU is 5.4v and 2.41A.
    It works perfectly. (very useful because I can keep the PSU at home and use the cable at Java training, where the AC outlets are either used or hard to reach and USB ports on the front of each PC)
    Other owners of that SFF have also made cables.
  5. TMM
    TMM Modder
    12 Jan 2004
    mod a usb port...
    wire the + and - of a usb socket on your computer directly to a molex connecter. that way you can pull pretty much as much current as you want ;
  6. pr0xZen
    5 Nov 2004
    The molex passthrough would be very useful, but I will mostly be using this on a laptop
