Modding Quick Question: ATX to MicroATX
Discussion in 'Modding' started by toyomatt84, 29 Sep 2004.
  1. toyomatt84
    toyomatt84 What's a Dremel?
    1 Jun 2004
    Well, I've gotten down to the home stretch of my pc buildup, but was stupid enough not to think about this earlier. I've got a MicroATX mobo, and an ATX power supply. Anyplace in the USA that sells a converter plug? This would be kind of nice to have. :D
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Don't need one. The only differences between mATX and ATX is size. All the plugs and connections are exactly the same.
  3. toyomatt84
    1 Jun 2004
    Not quite, I'm looking at it, and the main lead plug has like 4 extra pins in it, on the PSU side.
  4. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    If you've got 24 pins from the ATX lead on your PSU...
    You've bought a server styled PSU, and you need a pin converter for that.
    The other poster's right, mATX and ATX are the same except for size, basically.
  5. tk421
    tk421 Idiot.
    15 Jan 2002
    i thought newegg had 24 to 20 pin converters ..cant find em there now ... a lot of the new psu's have 24 pin now, and lack the 4 pin P4 connector ...going to be a regular thing for the 775 boards and BTX also ...
    http://www.power-on.com/connectors-adapters.html <-- first one i found
    googled for "24 to 20 pin connector"
  6. toyomatt84
    1 Jun 2004
    Thanks tk421, that'll help a bunch. :D
    I know that google helps, but I was just curious as to if anyone had dealt with getting one before. That's why I asked before I went searching hardcore.
