Networks Quick Question: MAC Addresses
Discussion in 'Hardware' started by simon w, 4 May 2004.
  1. simon w
    simon w What's a Dremel?
    3 Nov 2003
    Am I right in thinking that a NIC's MAC address is printed on the card itself?
    (I don't have one to-hand at the moment to check myself)
  2. RTT
    RTT #parp
    12 Mar 2001
    Some cards may (i've had a 3com with sticker on it with the MAC printed) but no others I've had have done.
  3. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    same here...only 3com print them onto the card from what i have seen, but its easy to find out:
    start --> run --> cmd
    ipconfig/all
    done...
  4. simon w
    3 Nov 2003
    Is it possible to obtain the MAC address of a remote UNIX machine on a LAN? I've tried using arp & nbtstat, but neither seem to work :(
  5. RTT
    RTT #parp
    12 Mar 2001
    Should work fine from the windows command prompt (arp -r {ip address} or something?). Alternatively you could telnet/ssh into the unix machine and run ifconfig (assuming you have root).
  6. buzzy
    buzzy What's a Dremel?
    27 Dec 2003
    Ping the unix machine and get a response, then do "arp -a" to get a list of the current arp entries in the cache.
    Works for anything that responds to a ping (or any other traffic for that matter) but you have to be on the same network, ie not separated by a router.
    Cheers
    Buzzy
  7. simon w
    3 Nov 2003
    Cheers for the information guys :) Someone else told me about pinging then arp'ing yesterday as well. I'll give that ago later :thumb:
