Motherboards Quick Question on PCIe Lanes.
Discussion in 'Hardware' started by Parge, 11 Apr 2012.
  1. Parge
    16 Jul 2010
    Quick Question on PCIe lanes
    I have a Asus P8Z68 Deluxe. It has
    2 x PCIe 2.0 x16 (x16 or dual x8)
    1 x PCIe 2.0 x16 (x4 mode, black) *1
    2 x PCIe 2.0 x1
    If I put 2x GTX 480 in the PCIe x8 slots, am I ok putting an Asus Xonar DX in the last x4 slot, or will this impact the bandwidth of the two GPUs?
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    It shouldn't affect anything. It all adds up to be the same 20 PCI-E lanes no matter what config you use.
    Edit: Elton's response makes more sense than this one lol
  3. Elton
    23 Jan 2009
    The last X4 slot would run in X4 mode. No biggie.
  4. tonpal
    tonpal New Member
    27 Jul 2008
    If my understanding of the Z68 chipset is correct, the "graphics" PCIe slots are controlled directly from the CPU. The third x16 (physical) slot uses the PCIe lanes from the PCH so using it will not have any impact on the graphics performance.
    I am not certain how Asus have allocated the 8 PCIe lanes from the PCH. There is a possibility that the x16 black slot shares lanes with the x1 slots.
  5. Parge
    16 Jul 2010
    Ok yeah, this is what I was thinking.
    Should be ok I guess.
