I tried one in Edinburgh last year. Was a bit skeptical but thought it was quite nice actually. Wouldn't want to eat one every day though =)
lol i think if you had more than one battered mars bar a year - youd fall over and die, with cholesterol leaking out of every orifice in your body mmmm
Question: Why do certain cars (Peugeot 206 for example) elevate their rear when you pull the hand brake?
Because you then shift the car's center of gravity, forcing more of it's weight onto the front wheels causing it to enter into that less-than dignified posture. Or something to that effect. Or you can just go with Mvagusta's answer which is more than sufficient. Any good advice on countering a dandruff problem?
NHS advice: http://www.nhs.uk/Conditions/Dandruff/Pages/Treatment.aspx Other advice: http://tgel.com/uk/Site_Map.aspx http://www.lyndsaycabildo.com/tips-to-avoid-dandruff-dandruff-shampoo-dandruff-treatment/ This stuff has the most effective stuff in it, according to NHSD: http://www.dandrazol.co.uk/?gclid=CO2DtIbbjJ0CFU0A4wodoSgK2Q
Ah yes, that sounds more like what I need; something delightfully toxic. Will see if I can find some, or just order some from abroad. Thanks.
If you can't get Dandrazol, Nizoral is an alternative - they both use ketoconazoles as their active ingredient. Ketoconazoles are most effective because they treat the cause, not just the symptoms - surprisingly, most dandruff is caused by a fungal infection (think of dandruff as athlete's foot for the scalp ), and ketoconazoles are antifungals. Nizoral is available in supermarkets here, I'm not sure about Dandrazol.
I used Nizoral when i had a rather persistent dandruff problem; cleared it up very very quickly. T-Gel and Head & Shoulders did nothing so, consider this a recommendation for Nizoral. I don't really get dandruff any more so yay.
I'm looking for the 3-part wallpaper of longcat, but can't find it for the life of me. Anyone happen to know where I can find it? Also, 4chan is blocked at work. *Edit* This is all I've been able to find: I'm looking for the other two pieces as well...and, you know, higher res.
dandroof: I use Nizoral as directed. Also Apple cider vinegar on my scalp for 15 minutes before a shower then pantene shampoo. I'ver had wicked itching and inhumane insults before using the above treatment.
Does anyone have the google-fu skills to find a guide for fitting a new sunroof mechanism to a Peugeot 306 hatchback? If so rep will be given out
All 3 parts are in here (along with many many others ) http://4chanarchive.org/brchive/dsp...d=74148962&x=constructing+additional+longcats
FINALLY! I knew I'd seen it in there before, but there are just soooooooooooo many archived threads. That's exactly what I was looking for! Big ol' +rep to you! Also: I couldn't find the instructions, but: and should take care of it And you can make it as big as you want!
I'm trying to look for a program that I used to use a few years ago on my old desktop. It used to track my mouse activity (clicks) over my desktop and show this data in visual form as an overlay on top of the desktop with a colour gradiant representing increasing number of clicks for each area of the desktop. Does anyone know this program or one similar to it?
