Motors Quick question (whats this part)
Discussion in 'General' started by peteone, 28 Sep 2006.
  1. peteone
    peteone Minimodder
    5 Jun 2002
    Anyone tell me what the silver canister like thing is next to the oil filler cap on this pic?
    http://vw.dpgoldman.com/images/a419tdi.jpg
    Just Ive got a bit of a coolant leak coming from directly underneath it and was just wondering what it is.
    Cheers. :thumb:
  2. iddqd
    iddqd What's a Dremel?
    6 Feb 2006
    If you're referring to the silver cylinder cap with tubes coming out of it (lower left of the pic) then its the part having to do with the refrigeration for your AC. I think. Get confirmation, but I'm almost positive that's what it is.
  3. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    Is that not your fuel filter?
    Smell what comes out, does it smell like diesel?
  4. peteone
    peteone Minimodder
    5 Jun 2002
    After googling it does look like a fuel filter. I dont think the leak is coming from there, it seams its from something just underneath. Just hoping its not the head.
    Cheers for the help peeps.
