Displays Quick refresh rate question
Discussion in 'Hardware' started by Wicked_Sludge, 6 Feb 2011.
  1. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    i have an ASUS VW224T 22" widescreen monitor. newegg lists the refresh rate as "30 ~ 82KHz horizontal" and "56 ~ 76 Hz vertical". how does one interpret this? does that mean 76hz (ie. 75hz) would be my max safe refresh rate?
  2. Rofl_Waffle
    Rofl_Waffle What's a Dremel?
    24 Mar 2010
    Usually the highest number (in this case 72hz) is the refresh rate if you want to run the monitor at 800x600 resolution. That is indeed a very low resolution.
    The refresh rate at max resolution is still 60hz (typical). There isn't really a safe or unsafe refresh rate, because you will not be able to set the monitor to a higher refresh rate than it can display.
    Wicked_Sludge likes this.
  3. Wicked_Sludge
    15 Aug 2010
    that seems like a ridiculous way to list a refresh rate to me. why list a refresh rate that only works at a resolution much lower than the screens native (other than just for the sake of conforming to a nearly obsolete standard)?
    crazy engineers.
    oh well, 60hz it is.
    EDIT: also, repped :thumb:
