Apple quickie: which HD to buy for Macbook Pro?
Discussion in 'Tech Support' started by sotu1, 25 Mar 2009.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Hey guys,
    just a quickie, which type of Hard drive do i need to buy to upgrade my Mac Book Pro? Wanna go from 160GB to something considerably bigger! 500gb would be nice but i'll settle for 320
    Cheers guys
    Sotu x
  2. OleJ
    OleJ Me!
    1 Jul 2007
    You'll just need a 2.5" SATA drive. Only thing to note is it shouldn't be taller than 1/8 (standard height of 2.5" drives)
    I popped a 320 in mine a year back and haven't regretted a thing since.
  3. Andersen
    Andersen Brain for hire
    25 Nov 2002
    Damn that sure is thin. I presume you meant 3/8?
  4. OleJ
    OleJ Me!
    1 Jul 2007
    In our national price database standard size is listed as 1/8H.
    According to the specs of a random 1/8H WD drive this equals:
    0.374 Inches / 9.5 mm
    About the "H" size:
    The original floppy drives, both 8 inch, and 5 inch, were 3 1/2"
    high. The fractions are referred to that.
  5. Wopsh
    Wopsh Don't own a Dremel :(
    29 Dec 2008
    I upgraded my first generation MacBook Pro's HDD from 80 to 500 not so long ago. http://www.ifixit.com/ has step by step guides for this kind of thing. You will need both a small philips and torx screwdriver to open a Macbook so be prepared.
