Im building a system for my parents and im only using a duron...ive biult some Athlon XP systems before but is it necassary to use fans like the ones used on an Athlon XP? If anyone could reccomend a quiet suitable fan for a duron 850 then i would be very thankful!
the taisol 760 is a very good heatsink, and im sure any quiet fan will be sufficient...just rember that it wont necessarily be cooler unless you got case cooling...
u tell him RTT... well as said the taisol is defintly value for money and noise is what u make of it...
consider me TOLD! looks like its more than enough for a duron 850....im sure i can live with 30dB thanks y'ALL!
Don't forget that you could also splash out on an Alpha Pal8045 and use a quiet fan like an Evercool or similar! Would be rather more expensive than the Taisol 760 though, which should suffice for your needs.
true, im running that EXACT config. on my XP 1800 system in using right now (pal and evercool)....but it costs a lot...i want the CHEAPEST fan/heatsink combo because im trying to biuld this system for under 290 including monitor!!!
The stock Taisol 760 fan undervolts well on a Duron 850, mine's running much quieter at 7.5v, kills that 60mm whine. Excellent HSF :dude:
