Quiet PSU anyone?
Discussion in 'Hardware' started by eUphoria, 18 Jul 2004.
  1. eUphoria
    eUphoria What's a Dremel?
    9 Apr 2004
    Can anyone suggest a quiet PSU (120mm fan i reckon) that will put out a good stable 12v rail (im running a vapochill) about 450watts +
    Cheers!!
  2. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Antec TruePower or Antec TrueBlue 480 watt
    Ive got the TrueBlue and swear by it.
    Almost silent and very stable lines.
  3. scrumble
    scrumble What's a Dremel?
    18 Jan 2004
    Just put one of these in my PC
    X-pro 120mm fan PSU
    Theres a review article on Bit tech about three leading 120mm PSU. This isn't one of them, but it's nearly £30 cheaper than those in the review, and I can't imagine the others would be much quieter.
  4. unclean
    unclean SMP obsessive
    30 Dec 2003
    Tagan 480W
  5. Goldfish
    Goldfish What's a Dremel?
    4 Jul 2004
  6. scrumble
    18 Jan 2004
    Waddya mean broken? It works fine :worried: :D
  7. Skylined
    Skylined Minimodder
    3 May 2003
  8. Jim-retired
    Jim-retired Cooler Master
    19 Jul 2004
    Cooler Master is introducing a very nice PSU -- Real Power 450W. I have tested this unit and feel it is just as good or better than the Antec True Power 550W I have used. It will be available very soon.
    Jim
  9. eUphoria
    9 Apr 2004
    Thanks for the suggestions guys!! Will a good 450watt psu be able to comfortably power the following: A64+mobo, vapochill xe, 1 dvdrw, 2xhdd and a r9800p? My cheapy 450 is running the above but with only 1hdd - thinking of getting another you see :idea:
  10. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
  11. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    You can also find some information about it here :thumb:
  12. Firehed
    15 Feb 2004
    If a cheap one is running that, a good one will run that with several extra drives.
  13. Ataraxia
    Ataraxia <b>OOH BABY!!!</b>
    12 Mar 2001
  14. Simonsnet
    Simonsnet What's a Dremel?
    25 Jun 2004
    I must admit I use my stock Chieftech psu. But I read a review on the Tagans when they were first on the market and was VERY impressed.
    Google for a review and I'm sure you'll agree.
  15. eddie_dane
    31 Jan 2002
    Or you could just read bit-tech.net :thumb:
  16. unclean
    30 Dec 2003
    Seriously, I'm trying to hear my Tagan 480W running at the moment.. it's just not working.. (the PSU is, just not the hearing of it...)
    The quality of it is also just crazy. I would really recommend it.
  17. simon w
    simon w What's a Dremel?
    3 Nov 2003
    I've got the Tagan 480 watt on my wish list :thumb:
  18. Ben
    Ben What's a Dremel?
    11 Aug 2003
    i do to. they are brilliant.
