Cooling Quiet v Effective best Air Cooling Fans
Discussion in 'Hardware' started by mickey123, 22 May 2006.
  1. mickey123
    mickey123 What's a Dremel?
    25 Aug 2005
    Hi,
    Im looking for the most quiet yet not at the price of effectivness, fans around.
    I need 120mm and 80mm.
    Any suggestions?
    Mickey
  2. atanum141
    22 Jul 2004
    The German made Noiseblocker fans, they aint cheap but my GOD are they quiet and throw out about 40cfm of air at 14db.
  3. hitman012
    hitman012 Minimodder
    6 May 2005
    Panaflo FDBs are fairly cheap yet quiet 80mm fans, while the L1As are very good 120mm models. For the best 12cm, however, you'd have to go with a Papst.
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Papst 4tw.
    I have like 7-8 random papsts here. :/
  5. Breach
    Breach Modding in Exile
    20 Jun 2005
    Arctic Cooling released a 120mm and 92mm versions of thier ultra quiet fans. Ive used thier 80mm version for a while now, my hard drives are louder than they are.
    Granted if you are looking for lots of air flow these might cut you short, but recommended for general system cooling
  6. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Papst and Panaflo are generally seen as the best for quietness/performance.
  7. mickey123
    25 Aug 2005
    Thanks for all the replies.
    I can't find the FDBs anywhere. Have they been superseded
    Does anyone know a shop that sells both the Papst’s and the Panfalo’s to save postage?
  8. Firehed
    15 Feb 2004
  9. mickey123
    25 Aug 2005
  10. specofdust
    specofdust Banned
    26 Feb 2005
    Papst or Panaflow. Those are the two best. YS-Tech are also very good, if you can get hold of them. They're noisier then Papst or Pana's, but cheaper, and tend to shift more air.
    http://www.dorothybradbury.co.uk/ - Go there for Panaflows, not sure of where you can buy Papst's these days in the UK.
    Don't bother with SilenX in any position of importance. They may be silent, but they hardly shift any air, and certainly not what they claim to shift. I'd never use them, exept in an otherwise unnocupied position if I really needed more airflow but didn't want anymore noise.
  11. mickey123
    25 Aug 2005
    Thanks specofdust, Appreciated
  12. hitman012
    6 May 2005
  13. specofdust
    specofdust Banned
    26 Feb 2005
    Hitman, along with google, you're one of the few resources in this world that everyone should have instantious access to, wired into their brains :D
  14. mickey123
    25 Aug 2005
    ^^^^ LOL
    Im taking it the smaller 80mm papst fans are not worth the extra over the panaflo's?
    There quite a bit more expensive
  15. specofdust
    specofdust Banned
    26 Feb 2005
  16. LVMike
    LVMike What's a Dremel?
    11 Aug 2004
    one name comes to mind Yates-Loon
  17. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    I use NoiseBlockers, and I love them. They provide a balance between silence and performance.
    -Mike
  18. specofdust
    specofdust Banned
    26 Feb 2005
    Yate-Loon fans are another great brand for those who are happy to have a bit more noise then panaflo's or papsts, and want more performance. Unfortunately, they're either very very rare here in the UK, or impossible to get. Froogle doesn't show up a single shop that sells them, and I can't think of any out of the ones I know that sell them either.
    But it's not the end of the world, between YS-tech, Nexus, Panaflo, and Papst, there are some supurb fans out there, those companies all good fans.
  19. Shadowed_fury
    21 Nov 2003
    Nexus are another highly rated one.
    Tbh, theres only a limit, and then you need to start using the fan dampers, and rubber clips to mount.
  20. Guest-2867
    Guest-2867 Guest
    Noiseblocker and Arctic Cooling stuff is the best i've ever used :D
