Peripherals R.A.T. series any good?
Discussion in 'Hardware' started by ninjaplease, 21 Mar 2012.
  1. ninjaplease
    ninjaplease I don't know what I'm doing
    11 Jan 2012
    Thinking about getting one, any advice?
  2. longweight
    7 May 2011
    Nooooooooooooooooooooooooooooooo!
    Awful software and a very low profile, gave me hand cramps!
  3. ninjaplease
    11 Jan 2012
    Damn I was starting to fall for them.. What do you use?
  4. longweight
    7 May 2011
    Logitech G700 all the way!
  5. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    I really like my 7. Use it for CAD and gaming. I like the extra weight and size over my logitech and razer lachesis.
  6. ninjaplease
    11 Jan 2012
    Coincidentally, the uselessness of my current mouse when CAD modelling is one of my motives for upgrading. Is the 5 much worse than the 7? My wallet prefers it..
  7. longweight
    7 May 2011
    I use the G700 for CAD :p
  8. Roboduck
    1 Dec 2009
    I don't think so? I just like the location and feel of the thumb buttons for macros in SolidWorks. If you are someone with small hands I would stay away from the R.A.T. series. It is a big mouse
  9. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    It's a fairly divided opinion product.
    I love my RAT 7, I claw grip quite predominantly so having some room to customize was very helpful. Palm rest pushed all of the way forward, grippy pinky/ring finger rest and thumb buttons positioned right where I rest the tip of my thumb. Its low height was also a selling point for me because it accomodates this style well, but be aware that this isn't adjustable save a 2mm taller palm rest. The main buttons, right in click in particular, are also very light. Not sure if this is just mine or typical of them all, but when people use my PC they often accidentally right click resting their middle finger on it.
    The software is indeed bad. I messed around with it at first but don't have much use for profiles or macros and what not so it's a non-issue for me, but if this is something you're interested in be warned.
    Keep in mind that it's a mouse. Objective things like build quality, software, dimensions and weight, all of those things you can look up and get reports of but no one can tell you if you're going to actually like it in your hand or not. I can't stand the G700 (or most Logitech mice) despite it being an objectively great mouse.
    EDIT: On the size of the mouse, it's not so much "large" as it is wide. You can adjust the length from being quite long or on the opposite end it's shorter than most mice. The height again is quite low.
    ninjaplease likes this.
  10. Roboduck
    1 Dec 2009
    True, its not for everyone.
    Best thing to do is try and find someone who has the mouse you are looking at or go into an electronics store that has them and try it out. See how it feels and make a judgment from there.
  11. ninjaplease
    11 Jan 2012
    I think I'mma go for the R.A.T. 5 for the looks and cost. Thanks for the advice everyone.
  12. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    I use the G700 for cad, before that 'twas the mx700! =D
    With a bit of work with autohotkey and you can make solidworks dance to your drum.
  13. modfx
    modfx Loft Gremlin
    11 Feb 2010
    I've had 2 rat 7s great mouse,like the feel and customisation. Unfortunately that only applies when they actually work. They both died mid game (the second was the warranty replacement) . Also the lasers are very picky about surfaces; refuses to work on one side of my exact mat and tracks funny on the other, colour seems to matter too it will track better on a light surface as opposed to a dark even if its the same texture. In the end, I used it either on my desk with no mat or on a piece of white a3 card I had laminated. It's just too much hassle and is overpriced.
  14. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Currently using a R.A.T 3 and have botters issues what so ever....
  15. mra123
    mra123 What's a Dremel?
    4 Apr 2012
    Was looking at these before, suggest trying them out in a shop first as they hurt my hand.
  16. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    The only RAT problem Ive had was some tracking issues. It would only track vertically or horizontally but would befixed by blowing on ther laser.
    A friend with the same mouse reported some rusting on the screws oddly enough. Its being sent back for replacement soon.
