Scratch Build – In Progress R-KAID-Я (15/5 Zero margins)
Discussion in 'Project Logs' started by quizz_kid, 24 Apr 2013.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice volume knob & nice stick of brass. :D
  2. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thank you Waynio!
    Gonna find some time for this little project tomorrow
  3. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Got some work done today
    I started by making the two casket pieces flush with each other. I used masking tape to keep them in place.
    Then I decided to chamfer the four corners. Will give the console a smoother touch I think.
    Due to some miscalculations I had to remove some material from the DC/DC regulator. I milled away about 4mm of the heatsink.
    I had to modify the joystick as well, to make it fit.
    Made a small walnut disk for the joystick shaft
    A small chamfer along the top/bottom corners before final sanding.
    Made a decorative stencil for the top and used my stain painting technique.
    Also stained the two inner panels. These will be adorned by gold details later on...
    Stencil removed, and here´s the result. Quite happy with it. It will blend in better with the finish on later. I really like this walnut veneer btw, the grains look amazing.
    That´s it for today!
    And again, sorry for the poor photos. Shaky hands and Mac products don´t cooperate that well
  4. Cheapskate
    13 May 2007
    Beautiful!:D
    It would have bled like crazy if I had tried that. ...always does.:(
  5. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Really nice. You own steampunk spark. :)
  6. chris182
    chris182 What's a Dremel?
    6 May 2011
    That is truly beautiful. It's nice to see people taking time to make something for more than just it's basic function!
  7. Asouter
    Asouter --------
    18 Jan 2012
    The grain in the wood is gorgeous, I'd be in the same boat as cheaps, the stencil work is spot on. How do you stop the stain from running along the grain ? Witch craft me thinks
  8. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks Cheap! To not make it bleed along the grains I´ve come up with a solution described further down.
    Thank you Pranja. I personally don´t see my projects as steampunk, but can understand the references =)
    Thanks you Chris
    It´s not magic at all... I just put a bit of thickener into the stain. But even then, it can be tricky when it comes to the actual painting. You have to apply very delicate, and only from above, never swipe. I use a small sponge brush to carefully apply the stain. I use very little color, keeping the sponge very dry.
  9. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Ok. Art deco perhaps? :D
  10. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Perhaps... Its some kind of time travelling, no doubt.:)
  11. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Arhhh man!
    You are a wood working king!
    Need moar! :D
  12. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks Phame! And yes, the VIA-board could use some water cooling, IF YOU INSIST!
    Phame likes this.
  13. Phame
    17 Sep 2012
    Yes lets watercool it!? :naughty:
    Would be schweeeeet!
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    It's quizz_kid style to me now, :D I don't see it as any other style other than his own retro inspired meets new awesomeness, he described it best himself as some kind of time traveling.
    Just awesome, unique & with excellent functionality. :)
  15. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks Waynio. Don´t know about functionality yet though =)
    Update:
    Stencils for gold painting on the inner panels
    The result! It looks better than expected.
    The hook attached from inside
    And this is how it´ll work. When not in use, the joystick shaft will work as locking mechanism. Pretty simple, but I´m really proud over the solution. A black arcade balltop will be added to the shaft of course.
    Then I started on the push buttons. I made a simple jig for sanding them down to the right lenght.
    Buttons mounted in jig
    After sanding.
    Epoxy between button holding and brass ring
    All buttons glued
    And here´s that ninth button I talked about before. It´s a hidden little flat screwdriver for adjusting the friction of the hinges, securing the joystick when in use and opening the case. Proud over this one as well =)
    Here´s the volume dial. I had to cut it some
    Test mount of the volume knob. Looks amazing! =)
    Two-layer mesh painted in brass for the vents.
    Glued under pressure
    Then it was time for a test mount of the components. As you´ll come to see, margins are extreme here. I had to by a lot of spacers in different lenghts.
    Speakers amp mounted...
    ... with the SSD disk ontop. Not much space between them, maybe 2 mm. Had to gut it because of margins, sorry for that Kingston.
    Everything mounted exept the lithion battery. Again, margins are EXTREME!
    I may have to make a special SATA for this one
    And I´m really looking forward to making that VGA connector... or am I?
    I even had to sand the pins of the joystick to make it fit near the VIA board
    Just another angle
    Finally I had to remove some material from the case for the VIA board to fit
    Hmm... Memo for next build: HAVE MARGINS!!
  16. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Man your work is extraordinary. :thumb:
    random aside:
    Did you make those cam clamps?
  17. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks man!
    And no, those are classic "Tvingman" clamps :lol:
    They are quite easy to make though I suppose
  18. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    I have a question. What kind of things could you use as connector for of some of the tiny pins on this board? I´ll need something for PWR button, etc
  19. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Been having a lot of physical issues lately, so this project is on hold for now. A two week fever followed by hospital visits including removal of appendix. Recovery for some days now, then back to business hopefully.
  20. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    Sorry to hear that man. I wish you a speedy recovery so you can get back to posting updates asap. :)
