Modding Racing Simulator?
Discussion in 'Modding' started by GoTaLL, 21 Apr 2007.
  1. GoTaLL
    GoTaLL What's a Dremel?
    17 May 2005
    Hi.
    Been a while since i did a worklogg.
    This is something that wont be doen today but i can show you a small preview of what should be made.
    finnishing up the Supreme Commander mod as we speak but this is something i need to show too.
    I was asked if i could make a racing simulator.
    The questions started popping up and i really have to ask .. what would you use? how would it look, if money wasnt endless but still not empty pocketed.
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Racing seat, surround projector screen, surround sound.
    If you have enough space you might as well use a real car for the dashboard, steering wheel etc.
  3. Jipa
    5 Feb 2004
    The right place for this would be in the modding-section, not in project logs. It can then be moved here if you start the actual progress.
    The first thing that pops in to my mind is a welded square tube frame. A proper mounting point for a racing seat (don't forget the adjustments) and as large monitor as possible. I don't see projectors being too practical in such use. First of all it would require more room in both lenght and width wise, and secondly the lamps are freaking expensive.
    I didn't quite understand if you asked about the whole thing or just framework..
  4. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    I would make a "sit-in" simulator perhaps with some dualmonitors, some nice pedals and steering wheel. Don't know alot about the quality of those, but one of those simulator sit in boxes would be awesome.
  5. dutchcedar
    dutchcedar What's a Dremel?
    24 Oct 2004
    I would find out more about what Dale Earnhardt Jr. uses. Apparently, he's an avid 'puter guy and has a serious penchant for racing simulations... has a cutting edge set-up and uses it exhaustively. That would be a good place to start, anyways.
  6. GoTaLL
    17 May 2005
    Ok .. just had to ask .. :) .. i allready have the thing i think will be perfect..
    PNY asked me to make this Racing simulator and this is what i will be using.
    well it wont be a Pc to be used on a desktop at home ;) .
    1pcs of Formel Opel Lotus.
  7. mattthegamer463
    26 Nov 2004
    Oh man, I nearly had to go change my pants when I saw that car. This is going to be the greatest mod EVER!
    My suggestions are to cut some of the sides out to make the cockpit hole larger, that way when you are driving you can move your elbows more, because I assume more than F1 2006 will be played on this thing, and doing a 24 hour Le Mans won't be comfy if your cramped in too tightly.
    Can't wait man. I always wanted to do one of these except just a racing chair on a frame, but I don't have room to store it so my dream has gone uncomplete. Be sure to take lots of pictures.
  8. Jipa
    5 Feb 2004
    meh... OK so maybe you will have room for the projector&screen.
  9. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Not exactly the most flattering car ever, but it'll do nonetheless. :D Personally, I've always thought the perfect racing simulator would simply be a racing seat, maybe a bit of a roll-cage to make it realistic and then a steering wheel, projector, etc... Having a specific car/body would make it only realistic for a game featuring that kind of car, imo.
    That's just me.
  10. Guest-23315
    Guest-23315 Guest
    When i saw the words 'racing' and 'simulator' and then 'GoTaLL' i instantly guessed there really would be a racing car involved.
    I'll subsribe to this thread before I see any work, becuase i can allready tell where this is going.
  11. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Gut a PC steering wheel, rig up to the real wheel. Same deal with the pedals, so the resistance is right.
    Of course, if it's at all possible, rig it up so the real gauges work, and remove the on-screen ones. That would just rock.
    Aside from that, put the subwoofer back behind the driver, so you can hear the engine right. Leave the car on the spring suspension, and mount the sub so the mass moves up and down, so it shakes the entire car.
  12. mattthegamer463
    26 Nov 2004
    And add a cupholder. I'm sure that car doesn't include one.
  13. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    yup this should be great a moving simulator is alot better though but also not doable by most people been playing on one at uni latly and they rock (when they work)
  14. Bas van der Werff
    Bas van der Werff What's a Dremel?
    18 Feb 2007
    shoulded this be in modding?
    great idea btw if you have the space.
  15. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    wow can't wait to see want you do with this :hip:
  16. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    if you watch F1, especially during practice, you will see drivers in cars while they are in the garage (not just the pits) and there will be a screen that they look at. this screen is in a fiberglass enclosure that snugly fits over the nose panel. il continue to try to find a pic of this tomorrow as i am about to pass out (i have class in 4 hours :duh: )
  17. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    Wow, this is going to be insane.
    I'll second what itsjustacompaq said, but possibly use 3 monitors - one wide screen and two standard ones on either side, to give a sort of peripheral view.
  18. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
