Cooling rad shroud
Discussion in 'Hardware' started by uwannabigmak, 9 Apr 2005.
  1. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    what is a good thickness for a radiator shroud? im using 120 mm fans and want to get the maximum performance. however, i dont have that much room so i would like to make it as thin as possible.
  2. Nexxo
    23 Oct 2001
    1 inch minimum.
  3. englishpremier
    englishpremier What's a Dremel?
    10 Apr 2005
    I second that. 1" min in order to the reduce the deadspot. hope its a 38mm thick fan too.
  4. Firehed
    15 Feb 2004
    In theory the thicker the better, but if you're just looking for a pretty way to mount a fan it doesn't matter.
