Im planning to put a 2x120mm rad in the top of my lian li pc60, but am looking dimensions of various 2x120mm rads to ensure it will fit and too see how PSU intake would be affected. I know the XSPC R120-D will fit, but am interested to see if others are slightly smaller. All I need is the length of the rad as im pretty certain it will fit width. Thanks
OK BIX II is 278mm in length by 131 wide Thermochill is 298mm in length (taking into account the bleed screw) by 122mm wide. This is something that i took into account when mounting a double rad in the top of a Wavemaster. I did find that a PSU with the fan intake on the bottom was much better as no matter how close the rad would be it would always interfere with a PSU with the intake at the back so to speak Flyin Banana was a prime example Hope this helps
[ot]Paul... Ive missed flying banana up until now. I love it. I used to have a yellow and black RD350 too except mine was a powervalve. I still have it sitting in my shed. One day ill finish rebuilding it!
Thanks coolmiester. I have a tagan 480 watt psu atm but was considering changing it to something with dedicated pci-e connections for gfx cards. Thanks again for dimensions.
You will find that all shops/manufacturers list the exact dimensions of the rads that they sell/make.
