Cooling radiator queston.
Discussion in 'Hardware' started by r3Q, 1 Oct 2003.
  1. r3Q
    r3Q Minimodder
    31 Jul 2002
    sup guys.. im looking for a large LARGE radiator... like 10x10 with the right size tubes to use with a dangerden block... do you know of anywhere i could get one this size with the right size tubes? thanks. :confused:
    i was thinking somthing like this
    http://www.slickcar.com/productdetails.asp?ProductID=115
  2. Twernmilt
    Twernmilt What's a Dremel?
    23 Sep 2003
    are you looking for a 10 inch cube or a 10 inch square?
  3. r3Q
    r3Q Minimodder
    31 Jul 2002
    not a cube, a big thin one.
    i want to get a DD kit, but i dont know if i need a certain size ID rad. im not really sure how small the rad tube can be. :confused:
  4. Blackeagle
    Blackeagle What's a Dremel?
    1 Nov 2002
    There is a Ford truck heater core that has a finned cooling area of the size you describe.
    It's the largest heater core I know of, 10.75 X 10.25 X 2 from Ford tilt cab trucks built from 58-67 & C, CT, BEF, FA5 & 001 Ford trucks built between 58-79.
    This core has 5/8" inlet/outlets that you could slip 1/2" Tygon over pretty easy. This core has 22 flat tubes, 11 in each pass of it's double pass design.
    The only real draw backs to this core are:
    1) Where to fit it? It's so large I've never seen it used in a system.
    2) A rad this large will require a pretty large pump, like a MD-20Z or MD-30Z Iwaki to drive a high flow through it's huge size.
    3) Cost, it's expensive as cores go, around $80.00, although this is not unreasonable when you consider it will beat every other made for water cooling rad or any heater core for cooling.
  5. keir
    keir S p i t F i r e
    5 Oct 2003
    2-pass Double-row Low Pressure Drop Radiator specifically developed for PC watercooling based on the new high-performance Black Ice Xtreme design.
    More than DOUBLE the performance at the compact Black Ice Prime form factor: rated for 790KCal per hour (3134BTU per hour) or 919Wh.
    120 mm x 32 mm (4.72 inch x 1.25 inch) Double-row Copper core consisting of flat tubes for maximum heat conductivity.
    High-density louvered copper fin configuration for enhanced heat dissipation
    Built-in plenum chamber for increased performance and noise reduction
    Self-tapping and case mounting holes for easy installation of 120mm fans
    Now 12.5 mm (1/2 inch) pre-angled inlet/outlet barbed hose connectors
    Compact 150.4 x 128.6 x 43mm (5.9 x 5 x 1.69 inch) dimensions allows it to fit inside most mid-tower cases
    Designed to meet the performance demands of hardcore PC watercooling enthusiasts
    £59.99
    http://www.coolercases.co.uk/wc_radiators.htm
