Windows Rage - Anyone excited?
Discussion in 'Gaming' started by Da_Rude_Baboon, 28 Sep 2011.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    So is that latest patch/update fixing the texture problem? Or is it still ugly?
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I forced 8k already, but I haven't noticed any additional improvements. Far objects still look terrible. If near objects still look bad, i suggest you should do the same as it does help it look considerably nicer for things in the foreground.
  3. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    muddy textures? bad sky?
    it might be like that because of the auto balancer.. I'll take some more screens tonight
    it's nothing like described in this thread.. but being on amd I have to play at 30fps until they fix their driver..
    there are textures that are compressed to hell but it's very obvious.. nothing muddy about them- they are clear as day.. I almost want to put in the 460 to see what you guys are talking about
    or do I :hehe:
  4. IvanIvanovich
    31 Aug 2008
    Yep, the autobalancer sucks. Thats why Forcing 8k, or if you have over 1.5gb vram, you can go to 16k it makes it look a lot better as you are essentially bypassing the autobalancer. But it sounds like some things are very different for nvidia vs amd user. Each has it's own set of issues. I have nvidia, so all i know is that following the guide for the rageconfig.cfg and the beta driver has eliminated all of the tearing and pop in for me, and made it look much better except for distant object which are still terrible.
    It's not that the distant things look vague, which they should. It's that distant things look like sharply defined things with terrible textures. That is not the way to do it. They need some bokeh or something.
  5. thehippoz
    19 Dec 2008
    yeah lysol.. hope they get a texture pack- but in game it looks fine least to me..
    wish my back wasn't killing me right now, I'd probably pull a late one..
    *edit- some better shots where you can see the texture fails.. and some more good shots
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  6. Apocalypso
    Apocalypso Fully armed and operational.
    15 Sep 2007
    I've enabled the 8k textures with the rageconfig.cfg but I still think it looks woeful.
  7. Pete J
    Pete J Employed scum
    28 Sep 2009
    Ditto. I tried 16k but predictably ran into memory issues.
    And no SLI support sucks MAJOR donkey balls.
  8. phinix
    28 Apr 2006
    WOW!!! :jawdrop:Does it really look that bad?!!!:waah:
  9. thehippoz
    19 Dec 2008
    not really.. you have to play it to see- it's just certain textures in game.. amd are really taking their time fixing the beta driver
    I can't even play at 60fps because there's a bug in the fixed video driver for dual cores.. using a older driver- but you can see the graphics are decent
    check it out in 720p- was capped in 1080 on a 6970 (sorry about the lag and fps- game play is much faster without fraps)
    if ati could keep that quality on the 10.6 and fix the bugs..
  10. soviet_
    soviet_ Bantros
    17 Dec 2008
    This isn't a reply to anyone in particular, just in general to a lot of the negative comments I've seen on here and other forums.
    How anyone can say this game looks bad is beyond me. First time we've seen a game with true artistry being used but all because the textures are a bit murky and lo res at close range, apparently it's a huge ugly mess of a game and John Carmack can go and **** himself.
    Well, I for one think it's absolutely fantastic and not only to look at. The shooting mechanics are solid, as you would expect but still a lot of games get this feeling wrong. Character movement is just right and the racing is great. Voice acting is good, the characters look brilliant, even the general NPCs look better than some lead characters in other games.
    Of course I have some gripes as there's some texture pop in, although it's not been that apparent for me, and yes at close range the textures lack definition but I think the fact that everywhere in the game looks pretty unique and I haven't noticed a repeated area makes up for it. Obviously the launch was a bit of a mess and the game wouldn't even start for me until I messed around for almost an hour so I get why some people are pissed off.
  11. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    I haven't had any problems since the patch, and even before that it I was only having the texture pop in issue, and fixed that with a few tweeks. Game is running solid on my system and looks fine. I hear ATI is still having a problem but I can't confirm that. Nvidia has a guide on setting it up if you look around.
    -edit
    You can tell that the charters have a much higher resolution texture then the world.
  12. phinix
    28 Apr 2006
    I finally tried it yesterday, it doesn't look that bad I guess.
    However I found one thing annoying - every time I move fast to the left or right or other direction, textures are low res and first half a second or so, then change to high - like loading it slowly or something. Did anyone notice it too? Why is it happening, is it hdd too slow? Should I install it on ssd?
  13. thehippoz
    19 Dec 2008
    just beat it.. pretty short ending really
    would have liked to have seen a little more.. but the bfg was nice to see up close.. it was almost as big as supermonkeys toys
    can try this.. the textures load in once at the start, but after that it should be good
    http://forums.steampowered.com/forums/showthread.php?t=2154053
  14. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    Good find thehippoz. The hq high spec file has completely elimated the texture pop in.
  15. Pete J
    28 Sep 2009
    Finished it.
    VERY disappointed by the ending. The story was all over the place and I still don't know why I had to do any of the objectives.
    Luckily I'm in an indifferent kind of mood so I'm not too upset. The combat was more or less solid, though the melee should've had a wider area of effect.
  16. mav2000
    mav2000 In Training
    16 Oct 2010
    I like the gameplay, but I am just at the begining of the game as of now...seems to be fun though, nothing in the story seems to fit in right now...I wish the tasks were more than go here go there types.
    But all in all, I am enjoying it right now. BTW< whats the best driver for ATI and this game? Tried 11.9, but having all types of screen tearing issues.
  17. phinix
    28 Apr 2006
    Cheers, I will try that.
    Been playing it for a while and like it. Not love it, but like it. gameplay is nice, it "calls me back" every day when come back home, so its good:)
    So far I like it, will see what happens...:cooldude:
