Raid contrafribularities
Discussion in 'Hardware' started by Furymouse, 4 Mar 2004.
  1. Furymouse
    Furymouse Like connect 4 in dagger terms
    4 Feb 2004
    Hey all
    first off love these forums.
    second, I got myslef a wd 160 se drive with a promise tech ultra100 tx2 control card. then I got a seagate 160 se put them on the card and tried to raid them. it wouldnt raid. so I tried just ide on the card. only the seagate is showing up. so I falshed the controllers bios. still nothing. but the funny thing is when I run a wd disk check in dos. there it is.
    so anything blatantly obvious that I might have missed?
    Mouse
    ps
    yes I know they are diff brands, but checked around, perfectly ok
  2. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    each drive is on a seperate channel yeah? both set to master? I am unfamiliar with that card sorry, could you tell me what the menu system contains?
  3. Furymouse
    4 Feb 2004
    yes they are on 2 diff channels and set as master.
    But there is no menu or way to get to any menu that I can see.
  4. Xen0phobiak
    8 Aug 2002
    There lies your problem. You need to go into the cards menu (bios) and set up an array. If you do not get a prompt to enter the menu, see if the card has any jumper settings and/or try a different pci slot. My raid card doesnt like being in certain slots.
  5. Furymouse
    4 Feb 2004
    Well there is nothing on the card, absolute nothing.
    So I am going to do what I always do with computer probs.
    THROW MONEY AT IT!!!
    Just going to go out and buy a new raid card see if it will work then.
    Now I have another prob with another drive, but Ill post that in a new thread.
    Peace.
