Reviews Raijintek Enyo Review
Discussion in 'Article Discussion' started by bit-tech, 26 Feb 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I know beauty is in the eye of the beholder but did the beholder get punched in the eye on this one? ;)
  3. Cheapskate
    13 May 2007
    A $250 erector set that can only be assembled one way?
    You should have installed an ITX in it.
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    If Rajincopy wants £270 for an upright benchtable with a sneeze guard then it better come with a voucher for a full set of Cablemod cables, a dude who is good at cable management to install the system as well as a lifetime supply of canned air.
  5. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Was a bloody good laugh watching Antony put it together. :hehe:
  6. RedFlames
    23 Apr 2009
    Damn, Meccano really has gotten expensive.
  7. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Well kudos to them for trying something at least. Beats seeing another Obsidian or worse Fractal anything IMO.
  8. jb0
    jb0 Minimodder
    8 Apr 2012
    I bet. Not gonna lie, I laughed when I got to the "take half the case back apart to install the cooling" part.
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
    For you as a skilled modder the idea may have merit as it saves you the effort of stripping a case down to its skeleton and you can get straight to the modding part...
    But for normies?
    Even if for some reason someone wanted a vertical benchtable with some glass, no place to hide cables and no dust filters then the Thermaltheft ones would be much better as they are more understated in design, can be wall mounted and cheaper to boot.
Tags: Add Tags
