Hi there Photos taken this afternoon: I don´t know what option choose, to put the hdd racks, in mobo place, or down with the Corsair: 1º Option (this one I like it): 2º option: Back of the case: Rad: Cheers all Have a good night
I don´t know about painting: I have three options: - Black mate external, polish internal. - Black mate external, white internal. - Dark Blue external, white internal. Have anyone an opinion about it? Cheers all
Looking big & awesome Raikkok was thinking it would be a while before you started but it's well on the way . Suggestions about paint? run over all panels & bars with a light sanding to give it all something to tack onto, clean, prime, main paint & depending on the paint type clear 2 or 3 coats to finish, well that's what I do when painting, there are other modders who put a bigger effort into painting a case so it has a mirror looking finish & some use special primer but I don't see the need in that for a PC with it being something that shouldn't be handled roughly, any stuff I've painted & not added a clear coat is prone to scuffs coming off but anything I gave a clear coat has been solid & worn very very good .
Hi Waynio, nice to see you here Probably i will go to a shop or a painter, because i don´t have gun and compressor... Thanks all for the opinions
